way off topic. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-10-2015, 08:40 PM Thread Starter
SilentBob2's Avatar
way off topic.
Maybe with it being a little quiet around here you guys might not flame me too much.I'm working on a turbo project with my son in one of those little rice burners. 89 Honda crx with a integra b16 motor swap. We have spent the last couple weeks fighting this turbo kit and finally got it all hooked up and running. Everything seems right, turbo is spinning but we can't make more than 2 lbs with a 7lbs spring in it. The only thing that isn't the same is the 2 inch pipe coming from turbo to intercooler. Kinda messed that piece up. After intercooler to intake was 2.5 and I had extra so I came off turbo with 2.5. What is the chance that two feet of larger pipe is causing me to lose pressure. At a loss with it and being first time doing one has got me stumped. I know. A couple of you here have knowledge I will never have. Could it be as simple as needing to be under a load to get the boost we are looking for?
SilentBob2 is offline
post #2 of (permalink) Old 03-10-2015, 08:54 PM Thread Starter
SilentBob2's Avatar
Oh and we haven't drove it yet, just running it in the shop. Just want to make sure everything is right before we drive it. After I know its right we will be taking it to have it tuned on a dyno. This has become one expensive project but fun. Momma did buy me a tig welder and plasma cutter for this project, that's a bonus....
post #3 of (permalink) Old 03-11-2015, 10:27 AM
Good deal on acquiring the tools! More tools are always good!
You're not going to get full pressure until you can hold the throttle wide open for a few seconds, which I hope you're not doing in your shop.
Larger pipe will not cause a loss of pressure. It will cause a delay in reaching a given pressure, because of needing to pressurize a larger pipe volume, but I doubt that you could detect the difference without sophisticated test equipment.
Nice hearing from you, Bob!
B. Dash Fabrication
Jim_Lou is offline
post #4 of (permalink) Old 03-11-2015, 10:55 AM Thread Starter
SilentBob2's Avatar
Not holding full throttle just giving it a short burst and would just barely seen the gauge go from vacuum to the boost. Kinda figured that's what was going on. I've been reading endless posts on Honda forums and it always seems like nobody would give any definite answers. So I was hoping you would chime in on this so I thank you. Had to get the tig welder for the aluminum piping. Had to drive thirty miles either direction to find someone to do it. Thanks again... I will let you know how it works out....
post #5 of (permalink) Old 03-11-2015, 03:11 PM Thread Starter
SilentBob2's Avatar
Thanks again. We just had a successful test run. Everything seems to be working right. Wastegate is working, blow off valve is working and we are making boost. Definitely needs tuned. Sending the ecu out tomorrow to have set up with hondata software so it can be dyno tuned.
post #6 of (permalink) Old 03-11-2015, 07:59 PM
Official Historian
WILL's Avatar
Cool project.
WILL is offline
post #7 of (permalink) Old 03-11-2015, 09:09 PM Thread Starter
SilentBob2's Avatar
We built a sohc 1.6 for it and took it to the track and it ran a sixteen in the quarter. I made a deal with him last spring and bought a 1.6 doch and limited slip trans for him from hmotors and told him I would take the motor we built for my daily driver that I use to drive to work. By the end of last summer with some ecu changes he was able to run a 14.2. Not bad at all for a 1.6 litre. We put a turbonetics t3/t4 capable of producing 400 hp. It came with a 7, 11, and 15 pound spring. The 15 pounds is suppose to make 150hp. We plan on tunning with the 11 pounds and see were that gets us. It has been fun and a headache.the kit claimed to be for his car with that motor swap and the only thing that boltedup right was the ram horn header. The rest has been a mess.we called several timesand they finally said it was possible we may have received the wrong kit. We are just about done now so all is good.
post #8 of (permalink) Old 03-31-2015, 04:26 PM
elusive's Avatar
are you running an intercooler?
It's not what you have. It's what you do with what you have
elusive is offline
post #9 of (permalink) Old 04-01-2015, 03:04 PM Thread Starter
SilentBob2's Avatar
Yep, running intercooler.. Found out last Friday we need a lot more injector. Ordered a set of 1000 cc injectors for it the other day and we are scheduled to have it back to the tuner on the 13th. I will let you guys know how it goes....
post #10 of (permalink) Old 04-05-2015, 09:46 PM
Newbie
Hope your project runs without any glitches. good luck!
adrenalinejunkie is offline
Human Verification
