O/T - Train project update - Page 2 - Off-Road Forums & Discussion Groups
post #11 of (permalink) Old 01-28-2014, 10:03 PM
Bryan's Avatar
Will yours look like this when it is done?
https://www.youtube.com/watch?featur...&v=qdQ-2mnODCo
I drive over things.
Bryan is offline
post #12 of (permalink) Old 01-29-2014, 08:21 PM Thread Starter
Official Historian
WILL's Avatar
I can dream. It may be a long time before the track looks that good.
WILL is offline
post #13 of (permalink) Old 02-02-2014, 07:35 PM Thread Starter
Official Historian
WILL's Avatar
IT'S ALIVE!!!! I got it started and running this morning. Transmission is now identified too. It is a T-87.
https://www.youtube.com/watch?v=K254wAN4U44
Removed all wiring
New fuse block
New solenoid
New gauges- mechanical oil and water; voltmeter
New points, condensor and coil
New ignition switch and ballast resistor
Rebuilt carburetor
So far only ignition and starter rewired
Changed oil and filter
New sparkplugs
Cleaned fuel pump and fuel line from pump to carb
Still to do
Flush and refill cooling system
Replace throttle cable
Connect driveshafts
Clean fuel tank and fuel line from tank to pump
Obtain and install alternator
Tune carb
Reinstall body
Replace 6v lights with 12 volt bulbs
Wire lights
Make a 6 volt regulator circuit for bell and mars light motor
WILL is offline
post #14 of (permalink) Old 02-03-2014, 10:17 AM
That's terrific! Have you found a 12 volt starter for it?
B. Dash Fabrication
Jim_Lou is offline
post #15 of (permalink) Old 02-03-2014, 08:15 PM Thread Starter
Official Historian
WILL's Avatar
Everything I've read says a 6 volt starter works just fine on 12 volts, just like early CJ's.
WILL is offline
post #16 of (permalink) Old 02-05-2014, 04:28 PM
Yeah, that's true except, I think, except that it will overheat faster than a 12 volt if the engine doesn't start.
B. Dash Fabrication
Jim_Lou is offline
post #17 of (permalink) Old 02-05-2014, 05:59 PM Thread Starter
Official Historian
WILL's Avatar
6.5:1 compression 4 cylinder probably isn't much load.
A friend is working on making the first switch.
WILL is offline
post #18 of (permalink) Old 02-06-2014, 10:24 PM
Rio_Grande's Avatar
Looking good Will
Ya only go around once, best to enjoy it the first trip.
Rio_Grande is offline
post #19 of (permalink) Old 02-07-2014, 11:28 PM
That's awesome! Now all it needs is a 6BT......
spook2 is offline
post #20 of (permalink) Old 02-23-2014, 10:06 PM Thread Starter
Official Historian
WILL's Avatar
I got it loaded on the trailer under its own power. That was so much easier than using the come-a-long. It got unloaded onto its new track the next night but unfortunately, no video or pictures of that event.
Loading NAD train onto trailer. - YouTube
WILL is offline
Human Verification
