Dauntless V6 - Off-Road Forums & Discussion Groups
Old 12-23-2013, 11:03 PM
jeeper89's Avatar
Novice
jeeper89 is on a distinguished road
Default Dauntless V6
Hello, i have been rewiring my 68 CJ5 has a 225 Buick V6. My 2 questions, 1 is i have a fitting directly behind the carb. All the fitting had attached to it was a small rubber line. What is it? 2 is that from my ignition switch a wire goes to a ballast resistor and then to coil. Can i do without the resistor and how, Pros and Cons Thank you
Old 12-24-2013, 01:40 PM
Default
If your ignition came with a ballast resistor it will work without it, but not for very long. The ignition system is designed to run on about 11 volts. The resistor cuts down the running voltage from 14.5 to the designed-for voltage. There's a terminal on the starter solenoid that supplies direct battery voltage to the ignition system, bypassing the resistor, when the engine is cranking and the battery voltage is pulled down by the load. If you bypass the resistor and feed running voltage to the ignition system the balance between the coil and the condenser is changed, and the points burn out quickly.
As for what you might have on the back of the carb, if it's down near the bottom of the carb it's probably for the vacuum advance. I can't think of anything else that a '68 would have such a fitting for. Some carbs had a large fitting for a 3/8" or 1/2" hose to feed the brake booster, but more commonly in that era they plumbed a fitting directly into the intake manifold.
Where abouts in Illinois are you?
__________________
B. Dash Fabrication
Old 12-24-2013, 10:35 PM
jeeper89's Avatar
Novice
Default
Thanks, and i meant to say the fitting is on top of intake directly behind carb. As for a brake booster, all i have is a brake resorvior attached to the pedal. which i am still trying to figure out.
Old 12-24-2013, 10:57 PM
Default
Is it a brake booster?
__________________
B. Dash Fabrication
The Following User Says Thank You to Jim_Lou For This Useful Post:
jeeper89 (12-25-2013)
  #5
Old 12-24-2013, 11:04 PM
jeeper89's Avatar
Novice
Default
Well I'm not sure, i think its what they call a single reservoir. All my lines are attached to it and a rod is hooked to brake pedal. The fitting looks like a fitting you use to air up a basketball but a little bit bigger.
  #6
Old 12-25-2013, 03:53 PM
Default
Do you mean a single reservoir brake master cylinder? One reservoir of brake fluid and one tube coming off that gets split up and goes to all the wheel cylinders?
The fitting on the carb is probably for the vacuum advance. From the time vacuum advance was invented they used a metal tube to carry the vacuum signal to the distributor vacuum advance diaphragm. My '57 Chevy had a metal tube, and I think my '64 Jeep had a metal tube. My '78 Jeep had rubber hose. I can't recall when the manufacturers started using a rubber hose, but either will work.
The vacuum advance is strictly a fuel economy device. The engine will run fine without it, but use more gas under light load conditions. Just don't leave that fitting on the carb open - it will suck dust into the engine, and make the mixture leaner than it should be.
__________________
B. Dash Fabrication
  #7
Old 12-25-2013, 09:27 PM
jeeper89's Avatar
Novice
Default
Yes it is like you explained, so it must be a single reservoir brake master cylinder. with drums brakes all around that i think need some work cause it dont stop very quick.
Also that fitting, could i just put a plug in it or what would be the best option. Its got a plug on the back of the carb if that is where it use to go to.
Again thanks a bunch for your help.
  #8
Old 12-25-2013, 09:31 PM
jeeper89's Avatar
Novice
Default
Also forget to tell you, i am from Mattoon, IL. 30 Min south of Champaign.
  #9
Old 12-26-2013, 03:36 PM
Default
Does the distributor have a vacuum advance diaphragm? If so you might as well connect it up. Otherwise, yeah, plug the port.
I know where Mattoon is - I've gone through it many times on the way to Champaign. And for the last bunch of years, gone by on the way to the Bash in Indiana.
__________________
B. Dash Fabrication
  #10
Old 12-26-2013, 10:22 PM
jeeper89's Avatar
Novice
Default
I think I found the diaphragm. It already was attached to carburetor. I put some pictures on here, hopefully you can see the fitting.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
