compressor - Off-Road Forums & Discussion Groups
Old 08-01-2013, 05:29 PM
OIIIIIIIO is an unknown quantity at this point
Default compressor
Hi,
I have a 12V Puma air compressor mounted in my Jeep off the battery with a reset-able 80A breaker (IIRC) and then grounded to the frame and then 4 bolts through the rear wheel well hold it in place.
I'd like to make this a little "portable" so that I can move it between my Jeep and truck.
Any suggestions on some quick disconnections that would work will in these two applications for the wiring and then some suggestions on where/how to mount it in my truck (2004 F150 crew cab) that would be somewhat easy to get it in and out?
Thanks!
Patrick
__________________
why yes, yes i am a moron
Old 08-04-2013, 05:06 PM
Default
The connectors you want are from Anderson Power Products - Multipole Connectors - They look like this:
They're self-cleaning when they go together and are very reliable. Get the two-conductor like in the picture and run hot and ground. Then you don't need to ground the mount.
I would imagine that they're available on E-Bay, Amazon and similar places on line. I got some from an electrical supply company, but don't remember where it was.
As for mounting ideas, not having an F150 I'm at a loss, but you can figure it out.
__________________
B. Dash Fabrication
Old 08-05-2013, 08:18 PM
jdoggmoney's Avatar
jdoggmoney is an unknown quantity at this point
Default
Jim Lou is spot on with the connectors. As far as mounting... you got a toolbox in that truck? It may cost you a bit more in cable to wire it, but it will be out of the way and secure from prying eyes. That's where I keep my firefighter air bomb.
__________________
Is this the only hammer you've got?
Old 08-07-2013, 06:29 PM
Default
As for mounting it, why? Mount the power plug somewhere close to your battery. Then put a length of wire on the compressor sufficient to reach as far as you want, if that's only to the ground. Then you can leave it in the toolbox until needed.
__________________
B. Dash Fabrication
  #5
Old 08-09-2013, 05:22 AM
Default
Quote:
This is the way I have been starting to lean...
__________________
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
