Smoking brakes / anything else - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-06-2013, 01:38 PM Thread Starter
Novice
I noticed a significant amount of smoke from the right front of my jeep this morning, and not to long after that i felt a pull in the front end. I tried again with the brakes and I was still getting pull. So I pulled over and saw smoke coming from my front right wheel, which seem to be coming off of the rotor.
I've been having some death wobble issues which seem to have gone away with new tires. Not wanting to cause any further issues I had it towed home. After taking off the wheel I can still smell the awful smell that I believe is brakes thats smoked off.
Is there anything else on the front end that could have remotely done this? I have a good amount of rust on a lot of parts and was going to slowly replace them as funds become available. I took some pictures but really it doesn't seem to show much.
Should I just replace both front calipers and pads and call it done? Is there anything else that can cause that? I was just wondering for safety reasons if I am driving around on something that has issues.
I can post some of the pictures if it's helpful.
Thanks
2004 Jeep Wrangle Rubicon
Stock everything
Rubi04Jeep is offline
post #2 of (permalink) Old 07-06-2013, 06:26 PM
On a simple hydraulic brake system the only thing likely to cause that is a bad caliper - sticking and keeping pressure on the pads. If your Jeep has anti-lock brakes something in that mechanism could probably also cause that. I don't know the details of those systems. Still, I would say that a rusty, sticking caliper is almost certainly the culprit.
B. Dash Fabrication
Jim_Lou is offline
The Following User Says Thank You to Jim_Lou For This Useful Post:
Rubi04Jeep (07-06-2013)
post #3 of (permalink) Old 07-06-2013, 07:29 PM Thread Starter
Novice
Jim,
Thank you, I picked up some new calipers and pads, and brake hoses' today. Hopefully that does it. I replaced the rotors not to long ago (1-2 years), so I'm hoping they are still good. They look ok.
I'm also doing to change the front diff fluid, it's overdue, and cant hurt.
Thanks again!
Stock everything
post #4 of (permalink) Old 07-06-2013, 09:38 PM
JBTater's Avatar
Might be the unit bearings?
I had to replace both of mine and they were running hot as they got more worn.
On the TJ's they're a single assy with the hub and bearing together.
Easy to replace, but harder on the wallet.
Lift up the front and grab a tire. If you can rock it back/forth then the bearing's toast.
By "rock it" I mean as though the lug nuts were loose, only they aren't and the tire, hub, everything is rocking together.
NAPA Parts
Jim
__________________________________________
OMG!!! I look just like Jay Sherman.
JBTater is offline
The Following User Says Thank You to JBTater For This Useful Post:
Rubi04Jeep (07-07-2013)
post #5 of (permalink) Old 07-07-2013, 02:49 PM Thread Starter
Novice
I did the "rock it" test, and thankfully both front sides are sturdy. Sad to say this surprises me. Too many years of living in New England have left a lot of the parts rusty.
I've decided to replace the brake line hoses that go into calipers, and once they show up I'll swap out the calipers and install new pads.
Thanks again!
Stock everything
post #6 of (permalink) Old 07-16-2013, 07:33 PM Thread Starter
Novice
Solved
Thanks all for the replies. Swapping out the calipers and brake lines seems to have fixed the issue. It seems the front right caliper was rather seized when we got it off.
Stock everything
post #7 of (permalink) Old 07-17-2013, 06:49 AM
Glad you got it fixed. It's not an uncommon problem in general, but a bit unusual for a relatively new vehicle.
B. Dash Fabrication
Jim_Lou is offline
Human Verification
