front end repair/ upgrade? - Off-Road Forums & Discussion Groups
Old 05-26-2013, 10:23 AM
jeepjunky's Avatar
jeepjunky is on a distinguished road
Default front end repair/ upgrade?
So my 05 is hitting the 120K, I have started getting death-wobble when I get close to 50mph. I plan on replacing the ball joints, unit bearings, and rod ends. That with an alignment and verifying my long arm control arms are tight I expect my death wobble to die.
I have a JKS HD adjustable track bar, a HD tie rod. Who or where can I get a HD drag link that allows me to retain the HD parts I already have. I would like a drag link that allows me to change/ replace both ends. any thoughts?
Thanks
Old 05-28-2013, 10:01 AM
Default
Make one. A piece of 4130 tube, a pair of bungs and a few minutes with a welder. You may have to spend a little time getting the right ends, but once it's figured out you have drag link that can be rebuilt easily and quickly with parts available at any decent parts house.
Remember, everything's easy for the guy who doesn't have to do it.
__________________
B. Dash Fabrication
Old 05-29-2013, 07:16 PM
jeepjunky's Avatar
Default
I agree that making one would be fun. But the part that really scares me is the mount for the tie-rod... drilling through the rod or welding to it...this is my steering, If i kill my self, so be it, my family or someone else...not worth the few $$ saved...
Old 06-09-2013, 02:13 PM
jdoggmoney's Avatar
jdoggmoney is an unknown quantity at this point
Default
Before replacing all those things, maybe a quick check to see if they require replacing is in order?
Ball joints: Jack one side up at a time about an inch off the ground. Take the largest pry bar you can find and have someone pry up from below the tire while you watch the ball joints. You will see any excessive movement. This should also work for unit bearings, but at 105k, I agree, replace-em and if the old ones are decent, keep em as spares.
Rod ends: With the Jeep on all fours. Lay under the front end while a helper turned the wheel back and forth. I like to do this with the engine off. Again, you should be able to see any excessive wear in the ends.
It's not so much the track bar, but the mounts. Heavy duty track bars need solid, non-wallowed mounts to be effective. Check for cracks in the welds/frame/mounts and check very closely for wallowed out holes at both ends.
I'm not sure what your definition of "heavy duty" is. Is what you have is a beefy piece of tube with factory rod ends... the critical parts are not heavy duty.
Keep in mind that someone, somewhere, built all those stock and non-stock steering components you already have. At least if you build or oversee the building of a new HD draglink you can be assured that someone (you) is monitoring the "quality control" aspect of the build.
__________________
Is this the only hammer you've got?
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
