dauntless 225 V6 - Off-Road Forums & Discussion Groups
Old 12-05-1999, 06:52 AM
Default dauntless 225 V6
I have recently purchased a 71 CJ5 with an old probably aboused motor but I'm not ready to swap motors yet. I have dual exhaust with tailpipes exiting in front of the rear tires and it's backfiring through the exhaust. I've checked the timing to no avail. It backfires only on the right bank and I ran a wet and dry compression test with the folowing results: 1)165,2)175,3)160,4)150,5)170,6)175. the wet compression doesn't significantly differ from dry, and there is no change at all with the cylinder in question (#4cyl.). My question is whether there is something else I can check before pulling the head to check the exhaust valve?
Semper Fi!
Old 12-05-1999, 10:32 AM
dorfs is an unknown quantity at this point
Default Re: dauntless 225 V6
You can hook up a vacuum guage to the manifold. If it flutters fast at idle, it probably means a valve, or valve spring. Another thing to check is for hairline cracks between two cylinders in the dist cap. Cross-fire can sometimes cause this, by firing the spark plug on an open valve. If the firing order is correct, you can isolate which cylinder it is by pulling one plug wire at a time, until it goes away.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
