more of what to do... - Off-Road Forums & Discussion Groups
Old 11-13-2012, 04:52 PM
OIIIIIIIO is an unknown quantity at this point
Default more of what to do...
Hi,
I've got a rear end out in my 85 CJ7 wide track...
I have most but not all the parts and expertise for a swap to dana 44 front ford 9 rear with 4.56, ARB up front and mini spool in the rear...probably another $3k in parts and labor to get it done as I don't think I can do it myself...
Or i've got a bead on a stock wide track with 4.10 and lock right and narrow track rear with 4.10 and lock right for $500...seems pretty much bolt in...
Am i just being too impatient?
__________________
why yes, yes i am a moron
Old 11-14-2012, 09:22 AM
Default
The Ford 9-inch isn't the best solution for a Jeep because the pinion is so low. That's not a deal killer, but something to consider. Also, $3K seems on the generous side. There's no reason you couldn't do the rear yourself. The front can be a bit more challenging, but isn't impossible for a reasonably competent home mechanic.
I don't think it's a good idea to mix the wide and narrow axles, although on a trail-only Jeep it's probably not a big deal. But if both your current rear and the narrow-track are AMC 20s, swap the rear internals. A Dana 30 and CJ AMC20 aren't real strong, but would get you gears and lockers cheap, and survive if you don't beat them too hard.
__________________
B. Dash Fabrication
Old 11-19-2012, 05:02 PM
Default
Hi,
Just trying to come up with options...
To recap...I was planning on going SOA with my axle swaps...along with a new tranny, etc...
What if I didn't go SOA...should make things a bit easier with the swap correct? Then not worry about the tranny...or at least not for a LONG time...would be nice to have a manual tranny for the kids to learn on in a couple years...
I have a Currie High 9 center section in an early bronco housing which should alleviate some concerns in the back. And should be relatively easy to put it.
The the hardest parts I think would be putting all the gears/lockers in the front (which I wouldn't do myself) and then setting the caster on the front yet...
I would still have the lift springs on the CJ which isn't ideal but works well enough...
I would have stronger axles (dana 44 up front, basically an 8.8 in the back) with higher gearing (4.56 vs 2.73) ...and I would be back on the road. I think I already have room to fit a bit bigger tire...currently have 33"...I trimmed the rear fender and put on some TJ flares and I trimmer the front fenders as well with a modified flat fender look...
I would guess I could fit 35" tires with minimal rubbing at full flex...
That would allow me to get going with what I have rather than monkeying around selling stuff for a pretty big loss and trying to get something else that would work, ideally bolt in but in reality I wouldn't find anything like that...
Can you see any draw backs...major things anyway...things I might be missing in my thought process?
Thanks for listening!
Patrick
__________________
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
