TFI vs. HEI - Off-Road Forums & Discussion Groups
Old 01-16-2012, 09:17 PM
Novice
Uncl-N8 is on a distinguished road
Default TFI vs. HEI
Your opinion on Ford TFI ignition upgrade vs. the GM HEI distributon swap. AMC 258 I6cyl. Pros, cons, side notes, testimonials, comentary, snide remarks, exc... Or coments on any other 258 improvements. I look forward to your posts, advice, and assistance.
Old 01-17-2012, 11:11 AM
Caver Dave's Avatar
Caver Dave is an unknown quantity at this point
Default
TFI: available cheaply from junkyard parts, but sometimes too "complicated" an install for some folks to fathom
HEI: junkyard renditions are scarce, but available aftermarket ($100-ish) and easy setup (1 wire); some earlier oriental versions had mega-hard drive gears that destroyed camshaft gears, but those haven't been seen in a long while
Both are a HUGE improvement over points, so we'll bypass ALL of the Ford-vs-Chevy kindergarten crap that usually follows this type of question!
__________________
Caver Dave
'72 "Mossy Edition" Commando
the Trail Forge
Old 01-17-2012, 06:11 PM
WILL's Avatar
Official Historian
WILL is an unknown quantity at this point
Default
Do both. Use a TFI type coil and an HEI module with the stock distributer pickup. Change the distributor cap and rotor to the large style.
__________________
Old 01-18-2012, 12:45 PM
Caver Dave's Avatar
Default
Quote:
The best of both worlds... An OE takeout/drop-in dizzy and a $15 HEI module (reportedly a bit hotter & longer life than the DS module) that doesn't use any special connectors! But you'd definitely want to do the base/cap/rotor upgrade!
__________________
Caver Dave
the Trail Forge
  #5
Old 01-18-2012, 09:00 PM
Novice
Default Mix and match.
So what you are proposing is that you would use the stock distributor, tfi big cap rotor and wires, but a gm ignition module and coil? Or the just the gm ignition module and the tfi coil?
  #6
Old 01-19-2012, 09:41 AM
Caver Dave's Avatar
Default
Quote:
- Stock Motorcraft ELECTRONIC dizzy
- Big cap/base/rotor/wires
- Ford TFI coil
- GM HEI module mounted to an AL heatsink (in place of the Ford DuraSparkII box)
__________________
Caver Dave
the Trail Forge
  #7
Old 01-19-2012, 11:27 AM
Default
Isn't that HEI module the one that GM put inside the distributor? Small enough to carry a spare in the glove box?
__________________
B. Dash Fabrication
  #8
Old 01-19-2012, 03:12 PM
Caver Dave's Avatar
Default
Quote:
Yeap... but what's a glove box? All I had was a door & hole under the dash!
__________________
Caver Dave
the Trail Forge
  #9
Old 01-19-2012, 04:59 PM
Default
That's all I had, too, until I bent up a SS box and welded it in.
So if GM could put it inside the distributor, why does it need a heat sink? Belt and suspenders?
__________________
B. Dash Fabrication
  #10
Old 01-19-2012, 06:08 PM
WILL's Avatar
Official Historian
Default
This piece of bent metal with the heat sink compound that came with the module is all the heat sink I have.
__________________
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
