11-18-2009, 08:16 PM
|  | Journeyman | | Join Date: Feb 2002 Location: gonzales,TX
| | homemade coil conversion
I want to do a soa or a coil conversion. I am having a hard time finding anything on a homemade coil conversion. Does anybody have any links ?
__________________
82 cj7 350,np435,d44/ auburn pro posi 9``/detroit
11-18-2009, 09:00 PM
| | Sawzall Poster Boy | | Join Date: Mar 2007 Location: Tuluksak, AK
Pirate4x4.com is a good spot to look, search 3 link and 4 link and you can read for days...
11-18-2009, 09:10 PM
I tried . I cant seem to get logged in. Haven`t logged in in a few years there. Thanks for the info , I will try google.
__________________
11-18-2009, 09:31 PM
Coils probably more work than I would like to do.  I will more than likely do leafs.  I have been working on a soa on buddys scrambler with him. I need to post some pics. I would like to find some free springs to put on mine for a nice ride instead of the old 2 1/2" s I have had on there fior years.
__________________
11-19-2009, 04:01 PM
If you are serious about coils look at the 3 and 4 link kits from poly performance and then some brackets from some where like ballistic fab. On the cheap using poly bushings at all ends with no adjustability, using square tube links, free coils and making all your brackets you could probably do it for less than $500 but you will have lots and lots of time in it if you want it to turn out nice.
11-20-2009, 07:57 AM
|  | Can't Get Enough | | Join Date: Dec 2006 Location: S. CA
A coil over conversion does give great articulation.....BUT.....it is a LOT of work....and if you get it wrong.....things can go wrong quick.....
For the money, it's hard to beat SOA.....great articulation....and easy to do using stock Wrangler springs.......it's basically a weekend project.....whereas the coil conv is about a month or longer....unless you buy a kit at about $5K.
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5 (35's on order), 4.10 gears, F/Det, R/ARB, Full Roll Cage,
D44 Flat top in progress...
11-20-2009, 08:39 AM
I guess I am just tired of the old 2 1/2" springs( rough) . I figure if I am going to do the soa I want some good riding springs. I have been reading alot thisn past week on springs. I have been in the hospital since Monday morning . Was supposed to be in less than 23 hours to take an infected plastic plate out of my skull  . Any way I would like to find some junkyard springs , maybe even wrangler or whatever. I just want a good ride. My buddy bought springs for 160.00 a piece for his soa. He has more money than time , I have more time than money
__________________
11-20-2009, 12:51 PM
I can relate to the rough springs....I went through that phase as well....
I'm running stock Wrangler springs....rides great....and they are easy to find....typically any 4WD house will have a bunch laying around that came off jeeps they lifted....and in most cases they will let you hand pick a set....I paid $80 for a set of 4.
If you think this is the way you want to go, let me know and I'll send you some detailed instructions and suggestions....it will help you avoid some of the 'gotchas' that I went through.
__________________
AKA DDawg16
11-20-2009, 01:21 PM
I will most likely go that route. I already have my springs outboarded for my waggy axle so that will save some time. I need to send a knuckle off to have it fitted with the high steer arms.
__________________
11-20-2009, 01:28 PM
Well wouldn`t you know. My neighbor just called to check on me and I told him to be on the look out for some wrangler springs. He told me he has a complete set sitting in the barn that I am welcome to.
__________________
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | All times are GMT -5. The time now is 09:52 AM. |
