11-02-2009, 07:03 PM
| | Sawzall Poster Boy | | Join Date: Mar 2007
Narrowing a front is pretty easy, I might be willing to lend a hand some day when i'm home for xmass. I saw a pretty nice job some one did out boarding a spring on a yj, i'll have to see if I can dig up the pics.
11-02-2009, 11:34 PM
|  | Official Historian | | Join Date: Sep 1999 Location: Conway, AR
| | Quote:
Originally Posted by BUCKYOO7 i would like to swap in a set of wagoneer d44 axles in my cj5. or should i have them cut down to wide trac with. I'm running 33inch swappers now i would like run 35s or?? we have not broke the stock axles yet and last Sunday my son tried or so it seemed . i want to keep it narrow i can get a set of waggy axles cheep now to out board the springs and do shackle reversal is there a kit for that this is something i plan on doing this winter and looking for ideas or options | Here is mine with uncut waggy axles under it sitting on 35s and SOA with 4 stock rear springs. I made my own brackets to outboard the springs but MORE makes a kit too. Full-Width Axle SRS Kit for Jeep CJs - M.O.R.E.
__________________
11-07-2009, 09:45 AM
|  | Enthusiast | | Join Date: Apr 2002 Location: milwaukee WI
now i need to know how to bring it back to 5.5 bolt what spindles and hubs and break parts i hope to pick up my axle today and then a chop saw and thanks for all the info I'm going to stay with the narrow track .my rear is a 20 with one peace axles the tubes are welded to the center how well will that set up hold up to 35 36 inch tires with a locker and now i need to find a locker for the rear when will the madness stop!
11-07-2009, 06:47 PM
|  | Moderator | | Join Date: Dec 2001 Location: Belleville, Illinois
I used early '80s Dodge Ramcharger outers. Five on 5 1/2, big internal-spline hubs and pretty nice brakes; much nicer than the Waggie setup.
__________________
EVERYTHING's easy for the guy who doesn't have to do it. B. Dash Fabrication
11-08-2009, 06:54 PM
|  | Can't Get Enough | | Join Date: Sep 1999 Location: The Plywood State.... Florida
If I remember correctly, you use ford rotors, chevy dana 44 knuckles, chevy dana 44 spindles (don't remember if it was big or small bearing), and chevy dana 44 stub axles (I think waggy 44's are the same) and chevy or waggy dana 44 caliper mounts and calipers. Searching for high steering or flat top knuckle here and at pirate4x4.com should provide the info you are looking for.
__________________
Political Correctness - Because people can't handle the Truth
11-08-2009, 08:07 PM
|  | Keyboard Implanted | | Join Date: Jul 2000 Location: southern new jersey
What you need is chevy small bearing spindles. But be carefull. There are two small bearing spindles. One for drum brakes and one for disc. You need the disc brake spindles. Ford rotors and hubs and that is it. Your waggies knuckles, caliper supports and calipers if they are good will all work. Now if you plan high steer you will need a chevy passenger side knuckle and then have both knuckles drilled and tapped for the high steer. Chevy driver side knuckles are already drilled and tapped.
__________________
What????
11-11-2009, 02:22 AM
| | Addict | | Join Date: Mar 2002 Location: Elk Mound Wisconsin
One other thing to consider and someone else mentioned is spring over or spring under. On my CJ I went spring over and Shackle reversal. Worked great, but I went through a lot of springs over the years. The spring over is real hard on them!! I think if I were going to do it again I would look into putting a TJ style Suspension in the front. I remember seeing adds a while back for someone making a conversion. But I am sure if you talk around you could find someone that has done it them selves I do not believe that it would be to much more difficult then out boarding, spring over, shackle reversal! Just another thought to add to an already tough decision!
__________________
Starting over isn't going to be as hard as not starting at all.
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 06:28 PM. |
