ADVERTISEMENT
Old 10-23-2009, 12:18 AM
HOGHEAD's Avatar
HOGHEAD is an unknown quantity at this point
Default Changing out my Power Steering unit ,,
Im changing out my power steering unit with one off a the same jeep with way less miles on it ,, Got the O-ring style & all the lines have been takin off,, now I have a coupler that the rubber is torn so Im replacing it with a new entire unit ,,Figured since I had everthing torn apart & I dont want to have to do it again,,, Is there grease inside of this unit??
http://i10.ebayimg.com/08/i/001/64/e5/6572_35.JPG
Whats the easy way to get it off the shaft ?? Is there a set screw holding it??
__________________
SOME BEACH ,,,,,
DEATH BEFORE 2 WHEEL DRIVE ,,,
Quando omni flunkus moritati ,,,
Proud American
Save the Earth... it's the only planet with chocolate
Old 10-24-2009, 06:21 PM
Caver Dave's Avatar
Caver Dave is an unknown quantity at this point
Default
That's commonly referred to as a "bell-joint" and yes, they are generally greased... not packed completely full, but enough to keep the squares inside the bell lubed.
__________________
Caver Dave
'72 "Mossy Edition"
the Trail Forge
Old 10-24-2009, 06:28 PM
HOGHEAD's Avatar
Default
Thanks Dave ,, This is the first power steering Iv had,, Might be the last..
__________________
SOME BEACH ,,,,,
Proud American
Old 10-24-2009, 10:41 PM
WILL's Avatar
Official Historian
WILL is an unknown quantity at this point
Default
Once you remove the snap ring, it should just slide apart.
__________________
  #5
Old 11-07-2009, 11:04 AM
HOGHEAD's Avatar
Default
All right I got it all apart after being rained on & installing A hydrolic unit on a freinds dump truck(told him he should have gotten it ready before he needs it).. So dose the ball with the pins that hold the square things screw off the Double D shaft?? As the new rubber is no way going over it (Ive never had that problem before) ,,
And should i replace the o-rings on the hose's with new ones & where should I find them??..
__________________
SOME BEACH ,,,,,
Proud American
  #6
Old 11-08-2009, 09:36 PM
HOGHEAD's Avatar
Default
Well I figured the darn thing out today,, By driving the pin that holds the little sqarw things that go up & down in the bell part ,, I was able to remove the old rubber & install the new one today ,, Tommrow the unit is going back on my Jeep come hell or high water,, Thanks for everybodys input on this,,
__________________
SOME BEACH ,,,,,
Proud American
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
