10-20-2009, 12:50 PM
|  | Moderator | | Join Date: Dec 2001 Location: Belleville, Illinois
| | OT What's this?
We were going through old boxes of my parent's stuff and came across this. It's a 0.004" thick strip of metal about 10' long with holes punched into it. I think it's silver. I can think of two possibilities:
Pop was into black and white photography which involves silver compounds, but not solid metal as far as I know.
Mom made jewelry years ago, but if it was to be melted into jewelry I would think a bar would serve that purpose better. DSCN3613a.JPG
Anybody have any ideas?
__________________
EVERYTHING's easy for the guy who doesn't have to do it. B. Dash Fabrication |
10-20-2009, 01:25 PM
|  | Can't Get Enough | | Join Date: Dec 2006 Location: S. CA
How soft is it? If you scratch it, is the metal underneath bright?
I actually looks like the inside of a NiCad battery....they take a stripe like that, coat it with a nickel substance, coil it up...shove it in the battery can...then fill with the cadnium electorlyte....
If it is that metal, it will be pretty stiff....if it's real silver, it will melt pretty easy....hit it with a torch...
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5 (35's on order), 4.10 gears, F/Det, R/ARB, Full Roll Cage,
D44 Flat top in progress...
10-20-2009, 01:46 PM
Yeah, I scraped it with my pocketknife and it's shiny under the oxide. Seems pretty dense, too - somewhere between steel and lead. It's more brittle than I would expect silver to be. If I fold it and work it back and forth a few times it breaks. I'll try melting a little piece of it, or maybe I'll take it to a jeweler to see if he can identify it. It's not likely to be a silver battery component since it's probably been in the box for over forty years.
__________________
10-20-2009, 02:09 PM
| | Way Outta Control | | Join Date: Sep 1999 Location: The Palouse
If it's silver, it could have been cut into anode strips and used in electroplating...
10-20-2009, 03:08 PM
Well, it's not silver. I used a little butane torch to heat it to a cherry red and it didn't melt. Also it's not magnetic at all.
__________________
10-20-2009, 03:47 PM
If it's not lead based, nor silver (since it doesn't melt) then I can think of only two uses: - Gas tank strapping (or the like), or
- Plumbing strapping.
is the coating any type of galvanization?
10-20-2009, 04:53 PM
It can't be structural for any use like that - it fatigues quickly and is only .004" thick. And not being ferrous it would have to be for some special, high-tech application. Stuff for common use would be steel. My dad scrounged a lot of strange stuff, but this is kind of exotic. The coating seems to be oxidation. At the center of the roll the metal is still shiny away from the edges.
__________________
10-20-2009, 05:14 PM
| | Old Hand | | Join Date: Dec 1999 Location: Ohio
Backing for patching holes in drywall/concrete/etc?
10-20-2009, 06:05 PM
Probably not - that would be galvanized steel most likely.
__________________
10-21-2009, 09:22 AM
|  | Addict | | Join Date: Mar 2009 Location: So.West Indiana
Probably not, since it's non-magnetic, but looks like the stuff they use to reinforce timber joints for Joists...
Also looks like the lead/antimony plates they use in batteries, but that would have melted like lead.
__________________
So Many Cats, So Few Recipes...
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 06:33 PM. |
