10-12-2009, 08:40 PM
| | Novice | | Join Date: Mar 2005 Location: usa
| | 85 CJ-7 Frame
I picked up an 85 cj7 this weekend .I went to look at a 79 that had a plow on it, but the iron worms went crazy on that one.Are 85 frame and 79 framesThe same?plow is a nice one on the 79, the body is actually inspectable on the 85. Both are CJ-7s. Thanks guys!!
__________________
Formerly Reddoogone.
10-13-2009, 02:50 PM
|  | Official Historian | | Join Date: Sep 1999 Location: Conway, AR
| | Quote:
Originally Posted by reddogeone I picked up an 85 cj7 this weekend .I went to look at a 79 that had a plow on it, but the iron worms went crazy on that one.Are 85 frame and 79 framesThe same?plow is a nice one on the 79, the body is actually inspectable on the 85. Both are CJ-7s. Thanks guys!! | Yes, the frames should be the same except for the transfer case skid plate.
__________________
10-13-2009, 02:52 PM
|  | Newbie | | Join Date: Oct 2009 Location: Da' Burgh
The only difference is the shock towers on the front shocks, they are bolt on and extended on the newer Seven frames. The older ones were short weld on towers. I put a 85 under my 76 and it al worked out great.
__________________
HighlanderCJ-7
If you do not stand behind our troops,
Feel free to stand in front of them!
10-13-2009, 03:14 PM
| | Quote:
Originally Posted by highlandercj-7 The only difference is the shock towers on the front shocks, they are bolt on and extended on the newer Seven frames. The older ones were short weld on towers. I put a 85 under my 76 and it al worked out great. | Oh yeah, I forgot about that too.
__________________
10-13-2009, 08:40 PM
Thanks guys. The plow should go on no problem . I was checking floor pans out. JC whitney has them for 54.00 there 19 gauge. quadra tec has them for 34.00, they don't say what gauge they are.
__________________
10-14-2009, 12:03 PM
| | Way Outta Control | | Join Date: Sep 1999 Location: The Palouse
IIRC the rear tub to frame mounts on a '79 tub are not in the same place as they are on the '85.
10-14-2009, 01:11 PM
|  | Mud in my Veins | | Join Date: Apr 2000 Location: Winston-Salem, NC
| | Quote:
Originally Posted by reddogeone I was checking floor pans out. JC whitney has them for 54.00 there 19 gauge. quadra tec has them for 34.00, they don't say what gauge they are. | The panels we used when repairing the tub of my brothers CJ7 were "less than stellar". Despite being marketed as "CJ7" parts, they were "Universal for CJ/YJ/TJ" parts that required a bit of massaging (additional cutting, bending, BF[rubber]H action) to fit properly... the rough shape, bends, & corrugation were the only pluses over just starting with a chunk of recycled sheetmetal.
I'll find out where his came from (*highly* likely they were JCWhipme versions), so you don't make that mistake!
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 07:18 PM. |
