10-10-2009, 08:12 AM
|  | Old Hand | | Join Date: May 2001 Location: SHARPSBURG , MARYLAND
| | Soft doors on a my CJ-7
Iv got a 1984 CJ-7 ,, Trying to get it ready for winter. It has a stock hard top and the metal doors are rusted real bad on the section that goes around the glass,,, Drivers side might be fixable but the passanger side I have to hold it togeather to get it closed with out braking it in two..
My question is will a set of soft doors off a 1985 CJ-7 with a soft top fit my 1984 with a stock hard top ??
Im sure someone has tryed this somtime,,
__________________
SOME BEACH ,,,,,
DEATH BEFORE 2 WHEEL DRIVE ,,,
Quando omni flunkus moritati ,,,
Proud American
Save the Earth... it's the only planet with chocolate
Reason: forgot somthing
10-10-2009, 08:27 AM
|  | Moderator | | Join Date: Dec 2001 Location: Belleville, Illinois
I don't think so. At least the doors on my stock Whitco soft top won't work with my stock hardtop. They latch closed against the rods that support the forward part of the top at the back of the door opening. The corresponding area of the hardtop is not in the same place. But like anything else, they could probably be made to work. They're just steel rods and vinyl-coated canvas.
__________________
EVERYTHING's easy for the guy who doesn't have to do it. B. Dash Fabrication |
10-10-2009, 08:42 AM
Nothins ever easy on these Jeeps.. Figured it would be a little different with this one being the newest Jeep Iv owned,,, With winter getting closer I have to make do till spring,, Maybe the Hard doors will be less than 300 on E-bay by then..
I figured these were to good to be true $75 for the two,, http://www.marylandjeepclub.org/phpB...6ddbd597c709a2
__________________
SOME BEACH ,,,,,
Proud American
Reason: needed to add something
10-10-2009, 09:58 AM
Yeah, those look just like my soft doors. They're not quite the right shape, but for $75 I'd get them and make them work. Worst case, hold them closed with bungee cords and stuff foam rubber in the gaps. As long as you don't ruin them you can probably get most of your $75 out of them next year.
__________________
10-10-2009, 09:39 PM
| | Old Hand | | Join Date: Dec 1999 Location: Ohio
| | Quote:
Originally Posted by HOGHEAD Nothins ever easy on these Jeeps.. Figured it would be a little different with this one being the newest Jeep Iv owned,,, With winter getting closer I have to make do till spring,, Maybe the Hard doors will be less than 300 on E-bay by then..
I figured these were to good to be true $75 for the two,, http://www.marylandjeepclub.org/phpB...6ddbd597c709a2 |
The only issue as to whether these doors fit or not should be the top rear corner of the door. If they are a nice rounded corner (about a 6" radius?) they should fit. If they are more of a sharp 90 deg. corner then it's more of a problem. I can't tell from your picture because the important area is cut off.
10-12-2009, 10:16 AM
| | Way Outta Control | | Join Date: Sep 1999 Location: The Palouse
If you can find a set of inexpensive lower half doors (YJ or CJ) you can get some upper door halfs from JCWhitney and have a full door for a reasonable cost.[quote]It has a stock hard top and the metal doors are rusted real bad on the section that goes around the glass[quote]I've a door sitting in the shed for the same reason. I wish someone would make that part. I know there's a fiberglass door maker out there who has duplicated that part in fiberglass. I would be wonderful if it could be released as a replacement kit.
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 10:52 PM. |
