10-05-2009, 02:56 PM
|  | Addict | | Join Date: Jun 2003 Location: Valdosta, Georgia
| | More Carb/Ignition Problems
Short history. 258, Nutter Bypass, Stealth HEI
Rebuilt my 2100. Ran fine for a week then all of a sudden would only stay running on high idle. This is why I suspected the carb.
Rebuilt it again. Could find no vacuum leaks anywhere. Same problem.
Started idling very unevenly - like a cylinder wasn't firing.
Pulled plugs - all carbon fouled. Repalced with new.
Pulled TFI junkyard coil and replaced.
Pulled 25 year old distributor. Gear good, cam gear good. Workings a little loose. Replaced with rebuilt dizzy.
Fired up - now will only idle slow - struggles - terrible throttle response.
Pull any plug wire at the dizzy cap and the motor will die.
I still suspect the carb is a contributor - rebuit on the way.
I feel like I have too many things going wrong all at once.
I'm already bald so I have no more hair to pull out - what should I be looking for?
__________________
No matter where you go, there you are.
10-05-2009, 03:27 PM
|  | Can't Get Enough | | Join Date: Dec 2006 Location: S. CA
| | Quote:
Originally Posted by 84_CJ7 - what should I be looking for? | 5.7L SBC TBI...or a 4.3L V6 out of a S10 Blazer....twice the power with half the problems....
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5 (35's on order), 4.10 gears, F/Det, R/ARB, Full Roll Cage,
D44 Flat top in progress...
10-05-2009, 03:35 PM
OK. In this motor
__________________
10-05-2009, 03:40 PM
Sorry....couldn't resist that......
Did you replace the float when you rebuilt it? It is one of the most common causes of flooding....
Also....are you running the stock fuel pump? And...is the fuel filter installed properly? There is a return line off the filter that sends the unused fuel back to the gas tank....if you don't have this installed correctly, you have too much fuel pressure at the carb and it can cause the needle to open up and flood...
__________________
AKA DDawg16
10-05-2009, 04:21 PM
Stock fuel pump. Stock fuel filter w/return line on top.
Tried two different brass floats - both were good.
__________________
10-06-2009, 11:40 PM
|  | Addict | | Join Date: Mar 2009 Location: So.West Indiana
Sounds like you *MIGHT* have something stuck in the needle and seat and letting it way too much fuel.
__________________
So Many Cats, So Few Recipes...
10-07-2009, 01:46 AM
|  | Keyboard Implanted | | Join Date: Jan 2000 Location: Bay Area, California
While waiting on the Carb (Which I suspect):
1. Verify each and every cyl has a spark.
2. Verify firing order.
3. How did you make sure no leaks? WD40 (or eq.)?
it has to be simple, just has to be...
__________________
Scott
1985 CJ7 T.H.O.R "He brought me up out of the pit of destruction, out of the miry clay, And He set my feet upon a rock making my footsteps firm."
-Psalm 40:2
10-07-2009, 06:52 AM
I agree with the needle seat but it has been cleaned and replaced 3 times. This thing really has me puzzled. That's why I decided to punt and get another carb, already built, to my specs. I'll worry about the current carb mystery at a later date.
Firing order is correct (triple checked)
Used propane to check for leaks. No luck
Son was helping me with spark test. He saw spark on #1- I did not. Later #1 lit me up!
I'm really hoping this is a carb with a gremlin and the new carb will make all of this go away.
__________________
10-07-2009, 04:43 PM
|  | I Might Just Know What I'm Talking About | | Join Date: May 2003 Location: Nebraska
It runs like this from the get go? Cold or hot? Or does it do OK for a few minutes then start to act up.
If it starts and runs OK for a few minutes, you might check you fuel tank cap. Just because you've been over everything else and fuel system pressure buildup can do weird things. Easy enough to check... remove cap and road test with rag in fill hole.
I will add that I did have an intake gasket leak once on my 4.2. Not to the point that it affected the idle, but I got an actual whistling noise from the area of the carb and after several attempts at finding the problem, I finally located the gremlin. I run a dual outlet Headman header. The Headman gasket disintegrated for some reason. I replaced it with the stock two piece Felpro gasket set and haven't had an issue since.
__________________
Is this the only hammer you've got?
10-07-2009, 10:18 PM
| | Way Outta Control | | Join Date: Sep 1999 Location: The Palouse
Have you tested the vacuum with a gauge at idle, WOT, etc? That can help pinpoint problems.
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 05:03 AM. |
