ADVERTISEMENT
  #11
Old 10-02-2009, 09:49 PM
Dirt Dog's Avatar
Dirt Dog is on a distinguished road
Default
Good post Aaron.
And I have to add (if I missed it and someone already said this)...........
for any given size it will be stronger than the original. (way more so on softer metals like alum.)
__________________
BUY MY CUSTOM STICKERS!!!!!!
  #12
Old 10-03-2009, 12:40 PM
TeamRush's Avatar
TeamRush is on a distinguished road
Default
Quote:
Originally Posted by Dirt Dog View Post
Good post Aaron.
Yup, the Heli-coil grabs MUCH MORE of the aluminum than any bolt could, so you really get a much STRONGER anchor for the fastener.
Spreads the load out a TON more, and gives you a concentrated STEEL contact area for the fastener to pull on!
You can't build anything strong without a good foundation,
And Heli-coils give you a strong foundation to do just that!
I have epoxied in Heli-coils also, but heat and a lot of epoxies don't get along, so using epoxy in aluminum heads for header bolts is a bad idea,
But for stuff like outboard motor 'Lower Drives' and motorcycle head bolts and case bolts, Epoxy works great...
You DO have to use a 'Dummy Bolt' with an Epoxy release agent on it to keep the epoxy out of the threads while the epoxy is curing, but you would be surprised how well they hold!
Epoxy, like JB Weld, will give you so much more anchoring power to the coil, along with strengthening the coil by backing it up and filling in gaps, crevices, ect. it's not funny.
Heat up the coil and it's surrounding material, and Epoxy like JB Weld will FLOW into the areas,
And you get a REALLY GOOD anchor! Doesn't take much heat either! Just warm to the touch, and as the parts cool down, it will SUCK the epoxy into the cracks and crevices!
Making for an anchor you will break the bolt off before you pull the threads again!
One thing I forgot to mention is,
Tapping aluminum is VERY Dependant on room temprature!
Aluminum expands and contracts two to three times the rate of steel or cast iron,
So tapping something in cold weather might mean the hole is actually too big when it gets heated up.
Try and keep the temp between 70° & 85°F when tapping...
You also need to know that a tap will JAM IN A BLIND HOLE very easily when you bottom out!
When you feel excess pressure on the tap (and the only way to learn is with trial and broken taps!) BACK OUT!
Square nose ('Bull Nose') taps are particularly ornery about sticking in the holes and breaking off...
One way to keep your tap from bottoming out and jamming in the hole is by dropping a ball bearing in the hole.
The drill left a 'V' shaped bottom, and something as simple as a BB or ball bearing (depending on hole size) will keep you from bottoming the tap out and jamming it up or breaking it off...
Through holes don't jam the tap nearly as often as 'Blind' or holes with distinct bottoms!
But you might not want to tap all the way through to keep the coil from walking out the other side!
Something old machinists know that general 'Mechanics' don't know is...
Stay away from high speed steel taps and keep to carbon steel taps when you are learning.
They both break about the same, snap off with no warning,
But a broken carbon steel tap can be shattered with a sharp chisel if you heat/harden the end,
You can't do that with a HSS tap! It simply won't shatter!
If you break a tap off and need to get it out,
Heat the workpiece so it expands,
Then turn a can of the computer 'Compressed Air' up side down so you get liquid,
And spray the tap so it contracts, then try to back it out.
The 'Freeze Off' bolt loosener works pretty good also for freezing the tap, but don't go overboard and contract the workpiece on the tap or you will never get it out!
If chisels and heat/cold don't do it,
You are down to burning the tap out with an EDM (Electronic Discharge Machining) Machine...
I've made several from common parts and used the welder as a power source for burning the tap away,
But if you only have one piece, it's always more economical to find a machine shop to do it for you.
Usually only costs a few bucks, and will save your Part/Work Piece...
__________________
So Many Cats, So Few Recipes...
  #13
Old 10-04-2009, 11:06 AM
jeepnut_nh's Avatar
jeepnut_nh is an unknown quantity at this point
Default
ya i know i know...they dont always work....but i'm batting about .750 for broken taps with one of these....not that i break many (maybe 6-8 in my life)
MSC Item Detail
__________________
'74 CJ5232 ci,Dana 30 & 44,basically a stock rig with fiber body
  #14
Old 10-05-2009, 10:27 AM
Default
I guess my question is:
Quote:
Why don't you take off the tail-shaft housing?
It would make the job a lot easier. It's really not that hard to remove the drivelines and divorce/drop the transfer case.
  #15
Old 10-09-2009, 09:28 AM
TOM85CJ7's Avatar
TOM85CJ7 is an unknown quantity at this point
Default
Thanks for all the great machining suggestions.
The tap was a Powercoil starting tap. I chamfered the hole without any luck. I ended up borrowing another STI tap from a friend. It was a Helicoil starting tap that he had cut off to make into a bottoming tap. To my amazement, it started easily, and went in nice and straight.
Got it done. All it took was a nice sharp tap. Took me less than 5 minutes for both holes. Thanks Powercoil for providing such a POS tap in your $35 kit. Next time I will only buy "Helicoil".
Now that the bolts are in and tight, I am considering putting a small tack weld on the head to keep them from coming out again. I could easily grind the tack off if needed.
I will post a pic of my crossmember and the offending bolts next time I have the Jeep in my shop.
Later-
__________________
Jeeps
  #16
Old 10-09-2009, 10:00 AM
Default
Rather than welding the head, consider safety wire - my favorite solution. If that's not feasible, how about tabs? Make a big washer out of a piece of sheetmetal. Tighten the bolt and then bend one side down to keep the washer from turning, and the other side up to lock the bolt.
__________________
B. Dash Fabrication
  #17
Old 10-09-2009, 10:11 AM
Caver Dave's Avatar
Caver Dave is an unknown quantity at this point
Default
Glad you got it knocked out!
Quote:
Keep in mind that bolts that are tight today, may be loose tomorrow. A tack weld to keep them from backing off, will also keep you from periodically giving them a snug to insure they're tight...
Safety wiring the bolts (after drilling the heads) could be a good alternative, should you find yourself trailside and need to remove/tighten them. I had a bud (former Airdale) give me a couple pairs of "safety wire pliers"... much smaller/lighter/easier to pack than a grinder
__________________
Caver Dave
'72 "Mossy Edition"
the Trail Forge
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
