10-02-2009, 10:05 PM
|  | Moderator | | Join Date: Nov 1999 Location: Troy, Ohio
I'll add this..........personal experience only.
Yes turning sucks, but it can be helped by adding a hydro boost pump and a external tranny cooler inline on the return side to keep from killing pumps on a weekly basis.
(being locked solid in the front is hard on pumps especially if your running any sort of diameter and tire like boggers)
10-05-2009, 10:41 AM
| | Newbie | | Join Date: Sep 2009 Location: El Campo Texas
well guys got her welded on saturday and i love it. got 8 inches of rain so i really got to test her out in the rice field and a shallow pond. turning in the soft mud aint too bad, better than what i expected. went through mud that i would have hesitated befor entering normally and had no problems. dont know the number of miles cause my spedo cable broke, but i went through a good 40 gallons gas. gave the welds a really good testing and i dogged on her pretty hard. i actually had a 1 ton chevy with 37 boggers leading me through the pond and he burried it and i just drove around him. lovin the weight difference
__________________
79 cj5 258I6 shaved head bigger valves header 4.10 33 12.5 bfg muds 2" shackle lift dual shocks engine oil cooler and reservoir 4 core aluminum radiator msd ignition |
10-08-2009, 07:44 AM
| | I Might Just Know What I'm Talking About | | Join Date: Apr 2002 Location: Scenic Southern Indiana
When I first put lockers in my Jeep I felt like you do now. Once I decided that the Jeep couldn't be stopped, I really started getting stuck bad and pretty often. Be sure you have a good tow strap and a buddy to pull you out. In the meantime, enjoy it! The difference is awesome.
10-08-2009, 08:18 AM
|  | Mud in my Veins | | Join Date: Apr 2000 Location: Winston-Salem, NC
| | Quote:
Originally Posted by upalittle Once I decided that the Jeep couldn't be stopped, I really started getting stuck bad and pretty often. | Ditto! Lockers will get you into the places spectacular "stucks", flops, & carnage are made of...
10-13-2009, 03:03 PM
|  | Newbie | | Join Date: Oct 2009 Location: Da' Burgh
Sounds like you already know the bad stuff. So weld it up and enjoy better traction. I have ran my last few D30's that way. The worst part was the turning radius, it seemed to double. The next biggest issue was using 4wd on the street in the winter, locking only one hub with big HP make it pull to one side. If all your in is mud and sand it should be fine.
__________________
HighlanderCJ-7
If you do not stand behind our troops,
Feel free to stand in front of them!
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 06:05 PM. |
