Quote:
Originally Posted by Curly55 doing a ring and pinion swap on my '94 yj's dana 30 and i dont have a carrier bearing puller or press. wondering what ya'll have done to overcome this problem? if ya'll have any ideas to help they would be much appreciated. one more thing... just so i have an idea how many times did any of ya'll have to remove the carrier during the process of adjusting backlash and carrier bearing preload? |
First off, I have to ASSUME you have the pinion already set up if you are working on carrier bearings...
Inside pinion (Depth) first for wear pattern,
Then outside pinion bearing for preload....
Then and ONLY THEN do you move to new bearings on the carrier.
Installing a carrier bearing set is VERY easy.
Two jaw puller will take them right off since there is a puller notch cast right into the Dana housings.
Find yourself a large, thick washer, and put it in the center of the carrier where the axles go, and drop a bolt in there to push on, and the bearings will come right off.
*IF*...
You don't have a puller, you can take the bearings off by cutting the cage on both sides, and letting the cage and bearings fall out,
Then using a 'Dremel' tool on the inside race.
Try and be as tender as you can when you get close to cutting through.
I often use a chisel and some 'Freeze Off' to get the inner race to pop when you get it cut most of the way through.
Remember, you are pressing the inner race on, and there is no seal, so you CAN mark or knick the carrier without effecting the carrier or bearing when cutting this thing off.
DO NOT DISCARD THE INNER RACE OF THE BEARINGS!
When you install, you will find the factory manual says it's perfectly fine to DRIVE the bearings back on with a hammer.
Use the inside of the old bearing as a drive tool to seat the new bearing without impacting the cage of the new bearing.
Coat the carrier bearing surface with a REALLY GOOD GREASE,
Something like a full synthetic grease or even 'Never-Seize' before you put the bearing on so it's easier to get off for final fitting...
And don't forget to use the old shims under the bearing.
The old shims will usually get you very close to where you need to be with a D-30...
Drop your new bearing diff in the case,
Pry the case up against the pinion gear (Pry ring gear to pinion gear)
And use feeler gauges to determine how much more in the way of shims you need for both sides.
(Make sure your races are seated on the bearings.)
Take the diff case out of the housing,
Use gear puller to remove the new bearings,
Install the same thickness of shims as you got with the feeler gauges,
And hammer/press the bearings back on and check again with feeler gauges.
You are looking for about 0.000" to 0.001" of backlash when done.
(noise isn't an issue in the front since you normally don't run full time in the front)
Here is a link to the section for the front axle in the FSM,
http://www.civilianjeep.info/84-86FS...Front_Axle.pdf
Start at about Adobie page 74 or so... (manual page G-156)
Some tips that might make your life easier,
Thick shims INSIDE next to the case so when you remove the bearing, you are lifting on one of the thicker shims.
Thinner shims tend to smear and let the gear puller loose, a BAD thing.
Buy yourself a shim pack.
About $20 and worth twice that in gold to have the correct shim at the right time!
Get yourself a good micrometer or digital/dial caliper.
None of those $20 tool sale or parts store cheapies.
Makes sorting and measuring shim packs SO MUCH easier...
Have an extra set of hands around when you are doing this.
It's VERY hard to hold the differential, and the puller, and the wrench, and the bearings at the same time,
It's also difficult to have a hand on both carrier bearing races AND the differential carrier at the same time when you are installing...
When you are setting PINION depth in the case,
Make sure you remember what you are seeing in the gear grease paint is BACKWARDS of which way the pinion needs to go in the case.
DO NOT use the crimp nut on the pinion threads when you are selecting preload shims and depth shims...
The crimp (Prevailing Torque) nut will eat up the threads in no time, leaving you needed new pinion and to do this again!
Use GREASE on the pinion nut threads! Even a dry straight nut will gall threads if you run it on and off enough times,
And you must run it on and off quite a few times as you are setting up the pinion!
When you drive the bearings on, make sure you put a board under the 'Down Side' bearing!
You don't want that bearing impacting something hard like concrete or metal while you are pounding or pressing on the 'Top' bearing...
