ADVERTISEMENT
Old 08-03-2009, 08:40 AM
Journeyman
cordova is an unknown quantity at this point
Default speedo gear question
I was watching my buddy change his speedo gear on a d300. The gear seemed to be off set and not centered in relationship to the top plate. Whats the deal here? I would think that if the unit were rotated from the original position, when installed into the case, it would move the bottom gear causing it to not mesh correctly. Yes, no? He kept saying "...man, I wish i marked it...". Is there a specific procedure for this job...ensuring the gears are meshing properly?
Old 08-03-2009, 05:26 PM
Novice
Ricochet870 is an unknown quantity at this point
Default
I don't know if it is the same procedure for the D300 that you are working on, but here is an excerpt from the instructions that I used to replace the speedo gear in my NP231 that might explain why he was twisting the gear in the housing:
"You will notice that there are a series of numbers located along the side of the speedometer gear housing. After you loosely install the retainer and bolt, select the appropriate tooth gear range (the numbers on the side of the housing) you just installed and rotate it until it is aligned with the raised dot on the transfer case before you tighten up the bolt."
If you would like the whole writeup with pictures and everything, let me know your email and I'll get it to you as soon as I can. Again, its an install guide for the NP231, but it might shed some light on the overall procedure for you.
-JD
Old 08-03-2009, 07:43 PM
bandhmo2 is an unknown quantity at this point
Default
Exactly what Ricochet870 said. The eccentric is to allow to adjust for different size gears, the ranges in tooth count for each position is usually stamped or cast into the gear housing.
__________________
Wilhelm
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
