ADVERTISEMENT
Old 07-22-2009, 11:22 PM
jeepjunky's Avatar
jeepjunky is on a distinguished road
Default Flat towing my CJ8
anyone know off the top of their head, what gear the tranny and txfr case need to be in, so the jeep can be flat towed. 4spd and Dana 300, 258. Thanks
Old 07-22-2009, 11:28 PM
bandhmo2 is an unknown quantity at this point
Default
Standard procedure is transfercase in neutral and transmission in high gear. However, this leaves the only thing turning the output shaft on the transfer case. Since the Dana 300 relies on the gears turning too through oil up to the bearings on the output for lubrication, the bearings may burn up.
The best way would be to disconnect the rear drive shaft at the axle and tie it up.
__________________
Wilhelm
Old 07-23-2009, 01:58 AM
thorjeep's Avatar
thorjeep is an unknown quantity at this point
Default
IIRC: my Manual says every 200mi or so, start the engine and run for a min or so to lube the D300. It doesn't matter what the tranny is in, just the D300 in neutral.
If going any distance, just drop the DS. Otherwise you can put fins in the D300 (Uggh) so it will lube from just the output shaft turning, or get warn full-floater axles (What I have) that has hubs that can be dis-engaged..
Have fun.
__________________
Scott
1985 CJ7 T.H.O.R
"He brought me up out of the pit of destruction, out of the miry clay, And He set my feet upon a rock making my footsteps firm."
-Psalm 40:2
Old 08-03-2009, 11:59 PM
WILL's Avatar
Official Historian
WILL is an unknown quantity at this point
Default
Quote:
The best way to tow it is to remove the driveshaft. The dana 300's gears do not turn while being flat towed. For short distances you should be ok though.
__________________
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
