07-04-2009, 11:33 AM
|  | Enthusiast | | Join Date: Sep 1999 Location: Boilermaker Country USA
| | What did this plug and wires connect to?
In my hunt to the get backup lights working, I came across this two wired plug. This female connector is round and looks to accept two male bladed connectors. The red wire has a white trace and goes somewhere in the main 85 wiring armor covering and looks to be about 10 gauge. The blue wire is much smaller and goes into the CJ electrical bulkhead connection. Any idea what this was used for? Thanks
__________________
1985 CJ with a transplanted 94YJ 4.0L motor, T176 tranny, mainly stock otherwise. ><>
07-04-2009, 12:24 PM
|  | Moderator | | Join Date: Dec 2001 Location: Belleville, Illinois
Where is it located?
__________________
EVERYTHING's easy for the guy who doesn't have to do it. B. Dash Fabrication |
07-04-2009, 12:37 PM
| | Quote:
Originally Posted by Jim_Lou Where is it located? | Right now it is hanging over the washer bottle. The pigtail is about 16 inches long. The blue wire runs straight back into the CJ firewall electrical connector.
__________________
07-04-2009, 02:11 PM
|  | Official Curmudgeon | | Join Date: Nov 2001 Location: Kansas
Is this them? It went to the ignition module. I’ll guess that it is not used on the ‘puter controlled models.
__________________ There are 10 kinds of people in the world.
Those who understand binary and those who don't. |
07-04-2009, 04:04 PM
|  | Can't Get Enough | | Join Date: Dec 2006 Location: S. CA
That does look like the plug for the Duraspark module.....
It looks like you have done the Mopar FI conversion which means all the Mopar stuff comes out.
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5 (35's on order), 4.10 gears, F/Det, R/ARB, Full Roll Cage,
D44 Flat top in progress...
07-05-2009, 12:40 PM
|  | Addict | | Join Date: Mar 2009 Location: So.West Indiana
That is the POWER PLUG for the facotry ignition DuraSpark module.
Large 'Red' with white trace, and blue wire.
Large 'Red' is the primary 'Run' power wire connected to the ignition switch.
Smaller 'Blue' is the 'Start' or 'Crank' power to the module when you are trying to get the engine started.
Powering up this circuit in the module retarded the timing about 8 degrees so the engine started easier when 'Hot' and compression was high.
If you decide to cut that wire out, there are people on the forums looking for that harness side connector,
So if you want to pass it on, make sure you cut it out with enough wire they can splice it into their harnesses...
__________________
So Many Cats, So Few Recipes...
07-05-2009, 01:01 PM
Thank you guys, I really appreciate your wisdom. It took months, but when I lifted out the 258, I left the entire orginal AMC harness in and did not hack anything. Then I dropped in the 94 4.0 with OEM engine wiring harness and computer. At that point, with 85 and 94 OEM service manuals, we began the sorting out the needed wires to make the 94 engine fire and run. I have a few 1985 wiring items left over and this one. I would be happy to share this harness side connector, just let me know.
Down the road, should I want to add a winch or electric snow plow lift, can I tie into this red wire with whire stripe or should I look elsewhere? I don't know how much this circuit can handle. THanks, Duane
__________________
07-05-2009, 04:24 PM
| | Quote: |
| Look elsewhere. That won't come close to handling a heavy load. Think battery cab, size.
__________________
07-05-2009, 06:32 PM
| | Quote:
Originally Posted by DuaneD
Down the road, should I want to add a winch or electric snow plow lift, can I tie into this red wire with whire stripe or should I look elsewhere? I don't know how much this circuit can handle. THanks, Duane |
That same circuit supplies current
To the alternator 'Excite' terminal,
To the ignition coil via a resistor wire,
And it should be fused for 3 to 5 amps.
I would say it's a BAD IDEA to connect anything else to that circuit.
I would have to really knuckle down and give it some thought, but I probably wouldn't use that circuit for anything but activation of relays that need to be 'ON' when the ignition switch is in the 'Run' position.
If you were going to wire a plow by using control relays,
They you could get away with that easy enough!
__________________
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 03:02 AM. |
