06-29-2009, 10:00 PM
|  | Enthusiast | | Join Date: Sep 1999 Location: Boilermaker Country USA
| | Heater Control System Shaft Attached to Push/Pull knob
We have spent the evening using NAPA's Dry Graphite Film on all the cables behind the dash and White Lithium on the bell crank joint bracket that's on the end of the heater system box near the gas pedal. The temperature control knob has come off the end of the push/pull shaft. Since I only have one shot with an adheasive, what would you guys recommend to use? Thanks
__________________
1985 CJ with a transplanted 94YJ 4.0L motor, T176 tranny, mainly stock otherwise. ><>
06-29-2009, 10:19 PM
|  | I Might Just Know What I'm Talking About | | Join Date: May 2003 Location: Nebraska
I don't know what the factory knob is like, but my CJ came with those fancy aftermarket aluminum jobbies already installed. Each has a set screw. Maybe it's time to bling it up!!
__________________
Is this the only hammer you've got?
06-30-2009, 06:42 AM
|  | Moderator | | Join Date: Dec 2001 Location: Belleville, Illinois
What JDog said. The factory knobs have a fairly soft plastic hub that can crack. I don't think you'll find an adhesive that will hold them, but a thick epoxy would be my best guess.
__________________
EVERYTHING's easy for the guy who doesn't have to do it. B. Dash Fabrication |
07-02-2009, 12:47 PM
|  | Keyboard Implanted | | Join Date: Jan 2000 Location: Bay Area, California
I would try Gorilla Glue.
Otherwise just get the black aluminum knobs on eBay, you know you want them
__________________
Scott
1985 CJ7 T.H.O.R "He brought me up out of the pit of destruction, out of the miry clay, And He set my feet upon a rock making my footsteps firm."
-Psalm 40:2
07-02-2009, 01:06 PM
Or fire up the lathe and make your own.
__________________
07-02-2009, 03:35 PM
__________________
Scott
-Psalm 40:2
07-03-2009, 07:42 AM
Thanks for the input guys. I got some epoxy from my local NAPA store and I will try that first. If this does not hold, or when it fails, the knobs with set screws will be the route. Appreciate the url.
__________________
10-02-2009, 11:48 AM
| | Apprentice | | Join Date: Dec 2007 Location: Philadelphia
On this same topic, has anyone seen better pulls for the heater, def, and vent instead of the cheap plastic push thru type? Something closer to what is used for the lights and windshield washer - with a screw down nut? All replacements I have seen (i.e. Quadratec and the like) are the push thru, plastic barbed style.
__________________
1980 CJ-7
10-04-2009, 01:09 PM
|  | Can't Get Enough | | Join Date: Dec 2006 Location: S. CA
See Thor's post above.....I bought the same set from Krage Motorsports....I bought some other stuff at the same time so I think my actual cost was less than what Thor paid....but still worth the cost....
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5 (35's on order), 4.10 gears, F/Det, R/ARB, Full Roll Cage,
D44 Flat top in progress...
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 12:21 AM. |
