ADVERTISEMENT
  #11
Old 06-24-2009, 03:48 PM
TeamRush's Avatar
TeamRush is on a distinguished road
Default
We are JEEP... RESISTANCE IS FUTILE...
You WILL be Assimilated!
__________________
So Many Cats, So Few Recipes...
  #12
Old 06-24-2009, 06:10 PM
RRich is an unknown quantity at this point
Default
Geez - you guys can't just help the guy fix his backup lights, can you?
I'm sure he's not using a superconductor anything on his Jeep. Are you?
Taz - yes, if he had .00001 Ohm resistance with the switch closed, it has resistance. But how many candlepower will that lower the backup light output?
How much brighter will it be if he was able to drop that resistance in half?
Geez, why make it complicated - the guy just wants his light to work!
GET A LIFE!
__________________
Too many idiots on the SWB to bother with them.
  #13
Old 06-24-2009, 07:32 PM
CJ7Taz's Avatar
Official Curmudgeon
CJ7Taz is an unknown quantity at this point
Default
Quote:
Originally Posted by RRich View Post
Taz - yes, if he had .00001 Ohm resistance ...
Would you cut me a 0.00001 Ohm resistor out of 18ga copper wire? Take your micrometer, it’ll be less than 0.02” long.
Until you learn a little about electricity, just stay out of the electrical discussions. Your comment could make him believe the new one he bought is bad when it isn’t.
__________________
  #14
Old 06-24-2009, 08:22 PM
TeamRush's Avatar
Default
GET A LIFE!
Actually, I'm playing with the neutral safety switch from a Chrysler automatic transmission (NSS and back up lights both in the same switch.
I'm getting 1.3 volts through the switch when it's 'Open',
1.1 Ohms resistance when it's closed,
And 0.73 volts across between terminals with circuits that shouldn't have anything to do with each other...
Since it's NEW, I accredit the resistance to the terminals used... Most of the internal terminals are an arc resistant substance, and they carry some resistance.
I accredit the flow of current when 'Open' and between internal terminals to the lubricant used to keep moisture out, keep corrosion down, and to keep the moving parts lubricated.
Every switch leaks a MEASURABLE amount,
And every switch has MEASURABLE internal resistance,
Enough so you can measure it with a common low budget Volt/Ohm meter...
Not really the issue, but enough to play havoc with stuff like LED lighting and sometimes enough to play hell with relays and stuff.
As for getting a life... I have one, and it's ANNOYING YOU!
As for the OP's problem, he answered it himself...
The switch is showing 7 Ohms No load closed, which is WAY TOO MUCH, Probably moisture or corrosion in the switch causing the resistance,
Connected load is 85-90 Ohms and that is about correct with the tail lights in the circuit,
Open the switch is showing "infinite overload" which I'm sure he means 'Over Limit' so when the switch is open, it's open...
For the reverse lights to stay 'ON'
Since the switch is a TWO TERMINAL, INSULATED FROM GROUND,
It MUST be a bad switch, sticking on internally from corrosion,
OR,
There is something running loose in the switch making connection.
REPLACE THE SWITCH AND ADJUST REPLACEMENT...
Not really an issue, and I though it was pretty clear his switch was SCREWED in previous posts!
(unless you were skimming posts and didn't get the gist of the conversation!)
__________________
  #15
Old 06-25-2009, 08:20 AM
Default
Neither of you, TR or Taz seem to understand a basic thing like a SWITCH! ON or OFF, simple but obviously too much for you guys.
Like always, neither of you understand that this forum is where folks can ask for help, not a place where you both can continually demonstrate your ignorance. And it's not a place where you can take your insane nature out on everyone else.
Take your frustration out at home - start by slashing your own tires - that'll show us!
The two of you have manged to drive most everyone off here - and onto other boards by your misleading drivel. This board was active, lots of posts, lots on information, but look at it now.
MODERATORS - is there a way when making an initial post that certain nut cases can be blocked for posting before they get a chance to try to comment?
Some other forums have this feature. Get with the program before you lose everyone - if there's anyone left.
__________________
  #16
Old 06-25-2009, 08:50 AM
Default
The only way that can be done is to totally ban someone from making any posts. I'm reluctant to take that step because they occasionally do add pertinent information to a thread. I have considered it on many occasions, however.
__________________
B. Dash Fabrication
  #17
Old 06-25-2009, 09:01 AM
CJ7Taz's Avatar
Official Curmudgeon
Default
I know that switch, I draw them all the time. It has no resistance closed and infinite resistance open. It doesn’t bounce when it’s closed or arc when it’s opened. Because it has no resistance when it’s closed it will handle infinite current. Nobody has been able to build one yet.
__________________
  #18
Old 06-25-2009, 01:13 PM
TeamRush's Avatar
Default
OK!
Clinical Assessment Only Of Original Post.
Quote:
Originally Posted by DuaneD View Post
Ok, now with the fuel sending work we are onto the reverse switch mounted on top of my T-176 tranny case.
OP has established the transmission is a T-176.
A lot of the times the reverse lights stay on all the time.
This would be the 'Issue' the OP is having.
Sometimes the lights are off when moving forward.
This would be CORRECT operation of the switch.
(reverse lights 'OFF' when vehicle is NOT in REVERSE)
I unscrewed the switch with a 15/16 socket.
Standard Reverse Light Switch size.
Good to know he removed the switch and tested it free of transmission 'Ground'.
Shows good testing procedures and practices.
Bench tested it and got a closed circuit of 7 ohms.
7 Ohms is too high for a closed circuit in just the switch.
You will ALWAYS read some resistance in a 'Closed' switch, but 7 Ohms would classify the switch contacts as a RESISTOR around here.
Obviously there is something WRONG inside the switch,
Carbon, Corrosion, Moisture, Dehydrated/Hardened Lubricants are interfering with the switch contacts if it's showing 7 Ohms resistance on the bench when 'Closed'.
Screwed the switch back in, hooked up the DVM, and got in the range of 85-90 ohms (with the tranny in reverse, out of gear we infinite overload).
OP states that switch was screwed into the case...
He DOES NOT state if the wiring connections were made or not.
With connections made, 85 to 90 Ohms would be about correct with the tail lights in the circuit.
Without connections made, the ONLY REASON resistance would have increased is something inside is moving around and getting in between contacts when the switch tries to 'Close'...
*IF*...
It's a SINGLE post switch, there isn't proper 'Ground' between swtich and case.
If it's a DUAL POST switch, (and most are) the switch has serious internal problems that can't be repaired in any meaningful or cost effective way.
*TURNED OUT TO BE A DUAL POST SWITCH IN A LATER POST BY THE OP...*
No, we are testing between the two pins on the switch...
Is this reasonable, right, wrong, or a switch bad?
I would say Jim_Lou answered the question,
But just for the spectators that can't keep up with the conversation...
The switch is doing strange things, and therefore classified as 'BAD' and should be replaced...
The red and white pig tail was not connected when we check this resistance.
This information would have been more helpful further up in the post, but it's good to know.
This makes the 85-90 Ohms totally unacceptable.
What do you think?
What I 'Think' is irrelevant, but thanks for asking...
The switch is 'BAD'.
It's probably as old as the vehicle/transmission, that would be 24 years of service, time for a replacment.
NOW... ARE YOU READY FOR THE FIRST ANSWER IN THE THREAD....?
Quote:
Originally Posted by Jim_Lou View Post
Replace the switch - it's not expensive.
I concur.
Under $15 for a quality piece, and easily sourceable from about any of the jeep places and parts stores.
NOW, ARE YOU READY FOR THE SECOND OPINION/ANSWER IN THE THREAD...?
Quote:
Originally Posted by TeamRush View Post
Jim is correct, you should be showing about 1 Ohm or less when the trans is in reverse.
And you should be showing 'OVER LIMIT' resistance when the trans IS NOT in reverse...
Sounds like the switch has given up internally.
OP's 'ISSUE' is resolved in this post from the OP...
REPOSTED HERE, for those that 'Missed' it!
Thank you guys.
I appreciate you taking the time to share some of your wisdom.
I have ordered a new backup Light Switch for my T176 tranny, part #52449.0252 from Quadratec at $12.99.
I will check resistance values of the new switch, compare to the old, and report back. Thanks
Since the OP's 'Issue' was resolved...
The conversation then progressed to what constitutes an 'Open' circuit,
'Closed' circuit,
And what could the 'Average' switch would read with the common, cheap, hand held DVM...
There IS NO SUCH THING AS 'ON' and 'OFF' as absolutes in common automotive switches...
There are 'Thresholds' where the switch isn't passing enough current to operate any given device ('Off') and when the switch is passing enough current (with resistance) to do the job it's intended to do ('On').
ALL Automotive switches will show some resistance when 'Closed',
And all automotive switches will show continuity when they are 'Open'...
This was a REAL PAIN for early computers/digital equipment, but the 'Variances' have been accounted for now.
The 'WISDOM' the OP spoke of was finding out that automotive switches DO show resistance and continuity when they 'Ideally' shouldn't.
EVERYONE WORKING ON ELECTRICAL SYSTEMS SHOULD KNOW THIS...
__________________
  #19
Old 06-25-2009, 02:02 PM
TeamRush's Avatar
Default
Now, this quote show a woeful lack of undestanding of electrical systems...
It's a switch, not a resistance! ANY resistance is unacceptable.
ALL ELECTRICAL APPLIANCES/CIRCUITS ARE RULED BY ELECTRICAL POTENTIAL!
There is NO SUCH THING as 'ON' or 'OFF'...
Let's see if I can make this something you can relate to...
It's like when we were discussing ignitions, and you couldn't seem to grasp the importance of switching times in the transistors...
Slower 'ON' ramps take up valuable time the coil could be MAGNETICALLY SATURATING,
Slower 'OFF' times ramp the magnetic field in the coil down,
Instead of letting it collapse all at once making for more spark energy in the secondary windings.
The POTENTIAL has to build up to a point where the device,
In this case a electromagnet,
Builds a strong enough magnetic field to induce a plug firing in the secondary field.
If that potential takes too long to build, then it takes full magnetic saturation away from the ignition coil.
If that potential isn't cut cleanly,
The magnetic field will collapse too slowly to induce a proper firing from the secondary windings...
In the case of a simple electrical 'Toggle' switch,
The 'Potential' has to overcome the internal resistance of the components used in the switch when 'Closed'.
ALL COMMON AUTOMOTIVE SWITCHES will show some resistance on even cheap Volt/Ohm meters...
Since the air is trapped in the switches,
And since that air becomes ionized when contacts are made & broken, all switches will show some continuity because of the electrical potential 'Leaking' though them from the ionized air inside...
Lubrication used to keep friction down and inhibit corrosion is also going to be somewhat conductive.
An 'Insulator' is actually a very low conductive material...
There is no such thing that 'DOSE NOT' conduct electricity since all atoms have electrons...
It's just how easy it is to pass a current, or 'Potential' across, the 'Insulator' material.
Glass is a VERY good insulator since it doesn't easily conduct electricity.
But EVERY 'Insulator' is somewhat conductive...
Copper is a very good conductor since it EASILY passes electrical potential from 'High' to 'Low'.
Every 'Conductor' also has some 'Resistance'....
__________________
  #20
Old 06-25-2009, 11:56 PM
TeamRush's Avatar
Default
Either we made progress, or Rich had a stroke!
__________________
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
