ADVERTISEMENT
Old 11-18-2008, 08:12 AM
PWARRIOR
Default Yj 2.5 Wont Accelerate!
Hi guys, I have a '90 2.5 yj 5-spd and it wont accelerate enough for me to even shift into second gear. I've replaced the O-2 sensor, and checked the fuel pump. Could it be a vacuum problem? Or EGR valve? Thanks for your help.
Old 11-18-2008, 08:44 AM
I am in the CPU
Default
How did you check the fuel pump? There's no way I know of to test the pump under load on the road. Did this problem crop up suddenly? Were any other changes made when it started? Did you check the backpressre at the tailpipe? Could the cat converter be plugged? Is the exhaust restricted. If you lift the hood at night, after running the engine does the cat converter or the exhaust manifold glow a dull to bright red? Have you check the MAP sensor?
Could it be a vacuum problem? Not likely, but have you checked the vacuum? If so, what are the readings?
Old 11-18-2008, 09:02 AM
PWARRIOR
Default Map sensor
I think the vacuum was 20in, no cat, no exhaust restrictions, how can I check the MAP sensor?
Thanks,
Paul
Old 11-18-2008, 09:23 AM
I am in the CPU
Default
MAP is checked via voltage
What is the fuel pressure?
  #5
Old 11-18-2008, 05:02 PM
Rio_Grande's Avatar
Rio_Grande is an unknown quantity at this point
Default
I am tossing my guess in for fuel pump. I had a similar problem with my TJ.
__________________
Join the Obarmy, protect your 'hood.
  #6
Old 11-21-2008, 01:19 AM
Aprentice
carnuck is on a distinguished road
Default
Did you recently take out the cat? Pieces of it may have fallen into the muffler to await the "right" time to cork the exhaust and slow your Jeep down. Pull out the O2 sensor and see if the power picks up,
  #7
Old 11-21-2008, 02:06 AM
RRich is an unknown quantity at this point
Default
When it won't accelerate, what does it do? Does it backfire? if so, out the top or out the exhaust?
Groan loudly?
Just run normal but won't speed up?
More info would be helpful.
Check the color of the spark - red and hissy? A snappy bright blue?Check it at a plug and check it right at the coil. It should be the snappy blue if the ignition is OK.
After you try it with the o2 sensor removed, try the propane trick to see if it's a lack of fuel. Search here for "propane trick," it'll tell you how to make the tester. Add some propane while you try to accelerate, if it "likes it" it's a fuel problem.
Did you, or anybody steam or pressure wash it recently? TPS's don't like it and frequently fail soon after.
Let us know.
  #8
Old 11-21-2008, 05:19 AM
Default
A link to the propane trick writeup is in the Welcome post.
__________________
B. Dash Fabrication
Untitled Document
HOLY CRAP Or Your Money Back -
Once you try it - we dare you to drive without it. To learn more click here.
Off-Road Videos -
ATV Reviews -
Own your very own Off Road Superstor.....
How many times have you pondered the idea of owning your very own off road shop? Let the staff at Off Road Innovations, one of the largest aftermarket off road accessory dealers in the US, help turn your hobby into a profitable career. Go to www.offroadinc.net for more info or just call 800-809-6088.
MSD Ignition Rebate!
Fire up with MSD Ignition and receive Cash for Cruising! Click on the link to find out the latest cash back rebate from MSD.
Powered by vBulletin® Version 3.8.1
Copyright ©1994-2007, Advanstar Communications Inc. // Off Road forums & discussion groups sitemap
