YJ small block chevy swap. - Off-Road Forums & Discussion Groups
Old 11-14-2008, 08:25 AM
Taz
Default YJ small block chevy swap.
I remember reading somewhere about a kit for installing a small block chevy in my YJ. Has anyone here done this? I'm curious about your experiences before I look further into this. Any thoughts would be welcome.
Old 11-14-2008, 09:23 AM
Default
It's not quite that simple... to do it right you'll need to change:
  • wiring
  • emissions
  • exhaust
  • motor mounts
  • radiator
  • associated accessories
  • engine to transmission adapter, or
  • If using GM transmission, transmission to transfer case adapter
  • Drive lines to take additional power
  • Rear end to take additional power.
  • Possible front spring mods
  • Fuel pump (if it's fuel injected)
  • Possible gas sender,
  • ... and the list goes on, this was off the top of my head...
IMHO, you usually loose more than you gain. If your intent on a V8, drop in an AMC 360.
  • What are you trying to gain from a V8 swap?
  • Will it really give you what you want?
  • Do you know how much this is going to cost (a whole lot)?
Old 11-14-2008, 10:16 AM
CJ7Taz's Avatar
Official Curmudgeon
CJ7Taz is an unknown quantity at this point
Default
First you need to know about the emissions laws in your state and what restrictions it puts on engine swaps.
I put a Chevy TPI in my CJ, but it was pretty simple. No inspections in Kansas, so that wasnít a problem.
I already had the T-176 transmission, which was strong enough to hold up to a larger engine so it was a matter of buying a bellhousing that bolted them together. I also had to buy a wiring harness and have the exhaust done. Iíd already swapped to a 3-core radiator when a solder joint came loose and let the old radiator go into the fan. For me it was pretty simple but I did a lot of research before I attempted it.
I donít know YJ so youíll have to look into what transmissions you can use or if yours will handle it. Itís a pretty common swap so you should be able to find a lot of information on it. Do the research and do it right and youíll enjoy it. Fail to do the research and go at it haphazardly and youíll likely be trailering it to sell as scrap.
__________________
Old 11-14-2008, 11:54 AM
Default
Check my advice in your other post.
What engine is in your YJ now? The back axle definitely won't hold up to a potent V8, and the front axle is marginal IMO although some folks have made them last for years. If you have the six cylinder the transmission is probably one that won't take it either. To do a V8 swap into a YJ you really have to want it. And have a thick wallet, even if you do all of the work yourself.
__________________
B. Dash Fabrication
  #5
Old 11-14-2008, 01:01 PM
JeepDawg's Avatar
JeepDawg is on a distinguished road
Default
If you are wanting to go with a newer engine....and long as it is basically hooked up the same way as it came out of the donor vehicle, emmissions laws are not an issue....
I put a 93 5.7L TBI in my 84 CJ....I used the 4L60 tranny that came with the engine (computer controls both the engine and tranny).
The project took me 2 years...but I was also do a frame up restore and spent a lot of time out of town on business.
Excluding the cost of the engine and tranny, the swap cost me about $1500. One thing leads to another.....
A stock D35 will not last long behind a SBC.....
You might want to consider the Chevy 4.3 V6. If you get one out of an S10 Blazer that already has 4wd...the xfer case drop is on the drivers side like your YJ...the engine is short so you have plenty of room...you won't have to shorten your driveshaft...you will most likely be able to use the existing tranny cross member with just a couple of mods...and it puts out about 220HP....and gets good gas mileage....
__________________
AKA DDawg16
D44 Flat top in progress...
Link to my Frame up Restore
  #6
Old 11-14-2008, 06:44 PM
myscrambler1 is on a distinguished road
Thumbs up sb chevy swap
hi most of these guys have heard this before but but may 2 cents is: if you want it do it.... take your time, research, dont be in a hurry, and your will love it when you get it done, i sure love mine.. it is a 305 built up in a 1981 cj8 scrambler, i dont know about a yj either but i would just get all the info on doing a cj and go from their,,,, i have hundreds of pic of my complete ground up or should say frame off rebuild if you need anything that i can do to answer any questions just ask
  #7
Old 11-23-2008, 12:09 PM
patrickmintun
Default V8 swap kit?
I also want to swap in a Chevy in my YJ. I have a 350tpi with ecm and a painless harness I picked up. not sure yet if I want 700r or th350, but I have one of each. I read some where you can use the front half of an s10 transfercase on the jeep transfercase to adapt. has any one done this? Also want to know about a Kit? or headers and mounts
  #8
Old 11-24-2008, 01:22 AM
JeepDawg's Avatar
Default
I would go with the 700r hands down....besides having the 4th gear, it is tougher (later models) than the TH350...the 700r is somewhere between the old 350 and 400 trannys....
As for the S10 xfer case....the setup used in the S10 blazers was typically a 4.3 TPI, 4L60E tranny and NP231 (I think). Basically, you can take the S10 setup and swap that into your a YJ without a lot of mods.
Motor mounts....I would suggest Novak over Advanced Adapter.
Headers? Don't waste your time and money....Jeeps are rock crawlers...unless you like to run your engine in the 5000 RPM range or higher all the time....the TPI puts out plenty of power....save the money so you can replace the D35 when you destroy it.
__________________
AKA DDawg16
  #9
Old 11-24-2008, 01:10 PM
mbalbritton's Avatar
mbalbritton is an unknown quantity at this point
Default
Looks like he's in SC, so no emmissions there to worry about.
__________________
The belief in a supernatural source of evil is not necessary; men alone are quite capable of every wickedness. - Joseph Conrad
  #10
Old 11-28-2008, 01:36 AM
Dex Dex is offline
Dex is an unknown quantity at this point
Default engine swap
my 75 76 77 cj5 fiber glass body all rewired head light to tail light all of dash and a built 350 chevy but--- just threw a rod threw the oil pan #3 cyl. bent the valve tore the block up so now im looking to get a 327 o and replaced all i could with stainless bolts , yes then i can take out a leaf or two and do away with the 7 qt oil pan thats in way of front drive shaft if i do so, need to look into my 3 speed trans and the transfer case?? if i can find out what they are nn its 44s front and back if im right ,,, not a jeep person like some on here i just like strong and thumping engines-----excertia excertia excertia BOW
__________________
ROLLIN'THUNDER
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
