On board air - I got rid of the airbox filter for a snout & K&N. That leaves enough room for a compressor for OBA. The Mitshubishi or Sanden round ones will fit nice, just make a bracket for it. Those were used by Dodge, Jeep, and some foreign cars.
Junk yard about $25 - get the fittings and a hunk of the tubes for it, makes life easy.
To drive it I cut the center out of a stock alternator serp pulley, then welded it to the front of the serp pulley on my alternator. Then used a short belt. You can do the same thing with a V belt. You lathe the center out so you can get to the nut.
A 90 lb shutoff valve, a lighted switch to turn on the clutch, safety valve, check valve, gauge, and a quick coupler. Direct, no tank. Airs a 35x12.5 from 10 to 28lbs in about 1.5-2 minutes.
I've installed about 6 of them like that.
If you want I can post pics.
On road I run about 28 lbs. Off road - desert terrain, 12, sometimes 10, sand 6-8. 35x12.50 MTR's.
In sharp rocks too hard, or too soft rocks will slice them easy. Usually 12-15 works best.
__________________
Too many idiots on the SWB to bother with them.
