08-27-2008, 08:45 AM
| | | small hard to find parts
where do you guys go to find hard to find parts..... like the ignition linkage gear behind the key and tumbler? I'm having a hard time finding one for my 83 CJ7. I've tried several of the auto parts stores and even tried the Jeep dealer. one place had one for a tilt wheel, but mine is a non tilt.
08-27-2008, 08:47 AM
| | I am in the CPU | | Join Date: Sep 1999 Location: The Palouse
Fill out your profile... year/model of Jeep, etc.
In many cases (CJ7, etc) that's a standard GM part found in any good NAPA or auto parts store.
08-27-2008, 10:28 AM
|  | Moderator | | Join Date: Dec 2001 Location: Belleville, Illinois
Welcome to the board!
What LEVE said, plus the junkyard. Many recent Jeeps use standard GM columns - '85 Jeep, same as '85 Buick.
__________________
EVERYTHING's easy for the guy who doesn't have to do it. B. Dash Fabrication |
09-19-2008, 02:26 PM
Tweaky,
I don't know if you ever found the part you were looking for, but if you are ever having a hard time finding a part and think a used part would be fine enough, let Phil at Max-Bilt Jeeps know and he should be able to help you. Besides the 100's of used CJ parts (I get to help with inventory right now...guess how fun that is!) he can also track down the NAPA part number for you. Our tech advisor works at Napa and getting you the part number so that you can just call up the store and tell them the part number might make it easier for the counter guy to help you.
Hope that helps!
09-19-2008, 05:01 PM
Welcome to the board, MX. Glad to see another CJ enthusiast. With two of them, no less. It's all I can manage to keep one running.
I wonder if Phil could find a master cylinder rebuild kit for my '78. My go-to local guy thought he had the only one in stock anywhere - it showed on a distrubutor's inventory - but when he ordered it the bin was empty. Doesn't really matter - he got me a new master cylinder instead.
__________________
09-21-2008, 10:09 AM
| | I Might Just Know What I'm Talking About | | Join Date: Jan 2000 Location: Charleston, South Carolina
Don't forget on the CJs AMC used parts from other automotive companies. If you are looking for something for the steering column, look at old GM cars in the junkyard. They are similar columns, and use a lot of the same parts. Probably a bit cheaper at the GM dealer, than trying to locate an AMC part.
09-21-2008, 02:21 PM
|  | Official Historian | | Join Date: Sep 1999 Location: Conway, AR
| | Quote:
Originally Posted by IN2DEEP Don't forget on the CJs AMC used parts from other automotive companies. | And carried that over with the Cherokee's and YJ's as well.
__________________
09-21-2008, 08:31 PM
|  | Carpal \'Tunnel | | Join Date: Jan 2004 Location: Indiana
You will find some steering column parts at most Chrysler and GM dealers. The Chrysler dealers have always been able to cross ref. Jeep Part numbers for me in the past. Often the price isn't as much as you would expect, have to try and find out.
I still get shifter boots for my T-5..
Here's a page I put together a few years ago. You will find links to pages with Jeep part numbers at the bottom, take those to a Chrysler dealer and see if it works out. Tilt Column Fix
Dale
09-21-2008, 09:35 PM
| | | Quote:
Originally Posted by Jim_Lou Welcome to the board, MX. Glad to see another CJ enthusiast. With two of them, no less. It's all I can manage to keep one running.
I wonder if Phil could find a master cylinder rebuild kit for my '78. My go-to local guy thought he had the only one in stock anywhere - it showed on a distrubutor's inventory - but when he ordered it the bin was empty. Doesn't really matter - he got me a new master cylinder instead.  | Jim,
Yah, the CJ is pretty fun. We have 3 running CJ's at our place...I just hope they stay that way, for while at least!
For the Rebuild kit, if you go to Napa, you can give them these codes: 10X1 3/4 brakes with manual brakes calls for a Napa number of 1355 line code UP, and 11X2 in brakes with power is a 946 and 11X2 manual brakes is 947. If they don't have them in stock, they shouldnt be to far out if they need to order them. Hope that helps! | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Untitled Document Off-Road Videos - Check out over ten years of extreme 4x4 action, product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it's all here. Rate them, share them and upload your own.
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Own your very own Off Road Superstor..... How many times have you pondered the idea of owning your very own off road shop? Let the staff at Off Road Innovations, one of the largest aftermarket off road accessory dealers in the US, help turn your hobby into a profitable career. Go to www.offroadinc.net for more info or just call 800-809-6088.
| MSD Ignition Rebate! Fire up with MSD Ignition and receive Cash for Cruising! Click on the link to find out the latest cash back rebate from MSD. | All times are GMT -5. The time now is 10:24 PM. |
