09-10-2008, 10:35 PM
| | Journeyman | | Join Date: Jan 2002 Location: Harford County Maryland
In a previous life I spent many happy hours as a tow truck driver. I have operated many different tow trucks and all have had MICO Hydraulic locks. Never had a problem with one not holding in hundreds of winching situations.
__________________
7T8C7
Was Jay2Jeeps but I sold 1
78 (mostly)CJ7 258 4.0 Head, Holley 4V, clifford Cam, 4" Superlift, 33x12.50's
07 FJ Cruiser 6MT stock
09-11-2008, 09:31 PM
| | Keyboard Implanted | | Join Date: Sep 1999 Location: Southeast Iowa
| |  Drove a tow truck on weekends for a few years. It had a tricky, vacuum-controlling lever on the steering column that worked somehow with the hydro-vac for parking and winching. I never did know exactly how that system worked.That was a ton-and-a-half-chassis with vacuum over hydraulic brakes; I think it used a Midland booster. ** Had a fork lift with the lever-operated MICO lock on it.... it was a single-axle-only brake system.
__________________
CJDave
A Jeep Skunkworks in "The Heartland".
09-18-2008, 11:44 PM
|  | Keyboard Implanted | | Join Date: Jan 2004 Location: Indiana
The frame stretch comment made me think about this guy... Just took some time to find it again.
Click the diagram above for some interesting reading.
That is page 22 of a very long winchathon but it is pretty good reading.
He likes big snatch blocks...
I'll get back to the brake line locks... Just other things to do right now.
Dale
09-19-2008, 06:35 AM
| |  Looking at those very carefully drawn sketches, I don't see the BEST way to increase pull without wrecking the frame of the winch vehicle, WHICH IS... use the anchor point for the snatch-block system and the Jeep pulls basically single-line. You have to set the Jeep offset just enough to pass the multi-part system past it and the anchor takes the strain, not the Jeep. I ran a winch truck that we owned when I was a kid that had a Braden M-5 with 300 feet of 5/8" cable, and if there is anything I learned from running that truck, it was that when you tie onto something, the winch will wreck it AND YOUR WINCH VEHICLE unless you use your head.
__________________
CJDave
09-19-2008, 06:46 AM
|  | Moderator | | Join Date: Dec 2001 Location: Belleville, Illinois
Yeah, that's NOT the way to do it. He has modified his frame (welded in 1" plate!) to take that pull, but a stock frame will be severely damaged that way. Don't ask how I know.
It doesn't take much more effort to run the lines under the Jeep to the anchor. Then it's all good.
__________________
EVERYTHING's easy for the guy who doesn't have to do it. B. Dash Fabrication |
09-19-2008, 08:22 AM
__________________
CJDave
09-19-2008, 08:46 PM
It's just a bit crazy to setup compound pulls for your average Jeep. Recovery Trucks have to sometimes I'm sure.
Enjoyable tangent... Go for it. I'm not doing anything with the thread anyway (can always start a new one when I get to it).
Winching and recovery can be more than a bit tricky... The more you know the better off you will be.
Dale
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 06:46 PM. |
