| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeep-Short Wheelbase All discussion of short wheelbase Jeeps: CJ, TJ, YJ |
08-05-2008, 08:57 PM
|  | Enthusiast | | | Join Date: Jan 2006 Location: Jacksonville NC
| | TBI Fuel pump I am wiring my fuel pump directly to a 12v source and not run it through the ECM?
By doing this, the pump will always send the same amount of fuel through the injectors. Will the injectors still pulse?
__________________
74 CJ-5 401tbi, T176,dana 300, 35 pitbull rockers,8274 warn winch, and someday I'll drive it!!!
08-05-2008, 11:16 PM
| | I am in the CPU | | | Join Date: Sep 1999 Location: The Palouse
| | Yes, the injectors will still pulse. The ECM does not monitor if the fuel pump is running, or not. All it does is provide two ways for the pump to be powered. |
08-06-2008, 02:19 AM
|  | Old Hand | | | Join Date: Dec 2006 Location: S. CA
| | Yes, this will still work but you open yourself up to some possible safety issues.
When under control of the ECM (via the fuel pump relay), the fuel pump will run under the following conditions:
1. For 2 seconds when you first turn on the ign (prims the fuel pressure line)
2. Crank or run signal.
One of the potential issues of not going through the ECM is that if the engine stalls, you could keep pumping fuel when you don't want it to....or if a fuel line breaks it could keep spewing fuel all over the place....not a good thing in a roll over...
JOOC, why do you want to bypass the ECM?
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5, 4.10 gears, F/Det, R/ARB
89 Cherokee, 4.5" Lift, R/D44, 31"x11.5
Both Never Finished
08-06-2008, 06:01 AM
| | I was just having some wiring issues. I did have it hooked up to the ECM and it did cycle for two seconds. Then I had some guys come over to "HELP" and ended up cutting wires in the harness and jacked it up!!
So now I think I have it all fixed. So I just wired it to the Ignition.
I will try the ECM tonight, If it cycles like it is suposed to I will leave it there.
Thanks for the info.
__________________
| | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 12:09 AM. |
