OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
  #11
Old 08-06-2008, 07:21 AM
Newbie
jgermann is on a distinguished road
Default
OK, I have taken it out before when I had to get the t-case rebuilt and then again when I replaced the clutch and didn't notice anything but when I was reading in the Chilton ( i think thats the book I have), it said to mark it and make sure it goes in the same way it came out for the balance. I just wanted to make sure I wasn't going to screw something up when I take it out today after work. I just have bad luck when it comes to these things.
Thanks for the help....
  #12
Old 08-06-2008, 07:36 AM
Super Moderator
Default
There probably are a few manufacturers that balance the shaft on the vehicle - It would make sense perhaps on a Rolls or Bentley or Mercedes limo - but I can't imagine Jeep doing it. On a Jeep I can't imagine ever being able to tell the difference driving down the road. Heck, I've never bothered to balance a driveshaft and lived to tell about it.
__________________
B. Dash Fabrication
  #13
Old 08-06-2008, 07:50 AM
CJDave is an unknown quantity at this point
Smile Balanced IN the machine?
I have never heard of such a thing..... Are you sure they were not alluding to the position of the slider....since you CAN pull it out and rotate it 180 degrees and re-insert it, that might be what they meant. I can easily see how that could be a problem.
__________________
CJDave
A Jeep Skunkworks in "The Heartland".
  #14
Old 08-06-2008, 09:42 AM
I am in the CPU
Default
If you look at the drive shaft, you'll see weighs welded on the outside tube. You bet it should be balanced... if you want a long service life out of it.
Now that you've lost the orientation for the splined shaft to the tube, you're kinda sorta out of luck. I've been successful in looking at wear patterns of the splines and the tube. By seeing what pattern was the tightest and slipping the shaft into the tube with that orientation, it worked. But, I could have just been lucky. Now I spray paint the shaft and tube to maintain orientation when I have to divorce the parts.
Otherwise, if you're really concerned, take it to a drive line shop and have the balance checked. It's worth the money for piece of mind.
  #15
Super Moderator
Default
Talking about a shaft with the slip-joint between the yokes, I take it? Rotating it 180 shouldn't bother anything, but 90 degrees out would be nasty. My driveshafts aren't keyed, so they can go back together on any spline.
I don't know that any manufacturer balances driveshafts in the car, but it wouldn't surprise me to hear that the really top-end vehicles were done that way to get every possible vibration out.
Remember the on-car tire balancers that fastened to the wheel which was then spun with an electric motor? They worked fairly well in the era of skinny tires.
__________________
B. Dash Fabrication
  #16
Old 08-06-2008, 10:58 AM
Pete88YJ's Avatar
Pooh-Bah
Pete88YJ is an unknown quantity at this point
Default
A one-piece driveshaft like a YJ rear won't matter -- just put it in the transfer case output and it should be fine.
If you have a 2-piece, with a spline in the driveshaft, it is important that it get put back together on the correct spline - so the front and rear ujoints are in phase correctly.
Glad it all worked out ok.
Pete
__________________
88YJ: Old, noisy, slow, and just generally wonderful. Wheeling Jeep.
99TJ: Less old, less noisy, less slow, daily driver Jeep.
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
