Do you have the Pulse Air system and are you using the original air cleaner housing?
If yes to those two questions, then check to make sure you are not getting exhaust from either of those two tubes.
I just discovered that my 84 I6 has a bad check valve and one of them is pumping exhaust into the air cleaner. That is un-regulated EGR. The first clue was that my idle speed improved when I took the lid off the air cleaner.
__________________
Can you hear the silence?
"Just because I can afford to lose money don't mean I should do it." Charles Barkley
