I just looked at a folder which has material relating to Flex Fuel Vehicles; material that I have collected over time. You can go to this site and find some of this info:
National Ethanol Vehicle Coalition ......and......
Iowa RFA.
As noted in one of the articles, the E85 is high in alcohol content and is therefore corrosive. All fuel-handling components have to be changed to materials which resist corrosion such as a stainless steel fuel tank and teflon lined hoses. Ethanol also acts as a solvent and will loosen any contaminants that are in the tank or other areas of the fuel system.
E85 has a higher octane rating (100 to 105) than does gasoline but the energy content per unit is lower. A vehicle that is not optimized for using E85 will typically show a 5 to 15 percent drop in fuel economy. Overall, the E85 retrofit thing is not quite as easy as it sounds. The proponents of using E85 are on record as discouraging the retrofit thing because they know that results are going to be less than satisfactory, and they don't want the bloom to go off the ethanol rose because of a few disappointed consumers.
