07-24-2008, 12:01 AM
| | Newbie | | Join Date: Feb 2004 Location: Long island NY
| | Help 92yj not start just cranking. NO SPARK
Ok here is the story my brother has a 92 wrangler 4.0 auto and his fuse box melted thanks to years of wrong size battery and mangled wires etc.. truck ran before the swap began. I had a 93 parts truck with 4.0 auto decided to swap harness / fues block. I took my harness off the 93 and my dad took off the 92 and tried to do the swap by himself. Not all the connections were the same the 92 had a three prong for the cps and the 93 had a 2 prong so i swaped the cps. swapped the cap and rotor. the truck will crank and get power to the coil but no spark from cap to plugs. So far ahve cleaned the cps swapped the coil cap rotors I think the swapped the ecm. Whats the next step a couple of wires leading the tranny arent hooked up im sure since i have only been down there half the time. Guages and lights work brake light work fan works etc. Have swapped out some relays but where should i check for the spark issue.
07-24-2008, 12:40 AM
|  | Can't Get Enough | | Join Date: Dec 2006 Location: S. CA
Go find another 92 wrangler and get the harness from it.
The early 90's were very dynamic years for those engines as far as the electronics whent.....in many cases things changed mid year......
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5 (35's on order), 4.10 gears, F/Det, R/ARB, Full Roll Cage,
D44 Flat top in progress...
07-25-2008, 10:48 AM
| | Way Outta Control | | Join Date: Sep 1999 Location: The Palouse
Jdwag, the harness remained stable from 1992 through 1993. Replacement CPS designs were not stable, hence the connector changes.Since the CPS was changed, it still could be the problem.
However, I'd be looking to see if the AutoShutDown relay was enabled. If it is enabled, the CPS is doing it's job. Then look for a problem further into the ignition circuit. If it is disabled, the fault likely lies back with the CPS.
Have there been any codes set or recovered?
07-25-2008, 09:33 PM
Thanks for reading thru that mess of a post I left. How do I check if the auto shut down relay was enabled, and how do I go about recovering codes?
--Thanks
07-26-2008, 04:33 PM
Check to see if there is voltage on the positive side of the coil. The ASD, when enabled, will provide voltage to this point. This point then feeds both the ignition and fuel delivery circuits. If it's not enabled... likely the CPS is not working.
Codes can easily be checked by Going HERE ....
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 07:35 PM. |
