| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeep-Short Wheelbase All discussion of short wheelbase Jeeps: CJ, TJ, YJ |
07-04-2008, 11:25 PM
| | Addict | | | Join Date: May 2003 Location: Forest Park,Georgia
| | hot to touch wires dad rewired my cj5 77 end to end, but now the 2 wires at the brake light switch at the peddle get very hot, i do need a fix, he added a couple more lights to the back and all work but im worried about a melt down, any ideas??
__________________
ROLLIN'THUNDER
07-04-2008, 11:31 PM
| | maybe what if i was to fuse the wire down going to the switch??
__________________
ROLLIN'THUNDER
07-05-2008, 07:30 AM
| | I am in the CPU | | | Join Date: Sep 1999 Location: The Palouse
| | A couple of questions: - Does everything work correctly?
- Did your Dad depend on the chassis as a ground?
If you can answer YES to both questions... the first thing you do is run a ground from the battery back to all those lights. In fact, refurbish ALL the grounds: - Battery to engine block
- Engine block to frame
- Frame to tub
You should not depend on chassis ground, as the frame and other components become rusted. That compromises the ground, and resistance forms. By running a seprate ground wire there is no return resistance.
If, after you run new grounds, the wires are still hot... then you've got to increse the size of the wires. The lights are pulling too many amps. Also, it may be a good idea to run them off relays. That will save the light switch in the dash from burning up...and failing.
07-05-2008, 09:26 PM
| | wiring hot as i look it seams to come off the fuse panel with a inline fuse wire to one side of the brake switch then out to the lights i guess?? its a fiberglas tub but ill check it all for ground or take off the other added brake lights he added, ...
__________________
ROLLIN'THUNDER
07-06-2008, 12:09 PM
| | wires hot took out a couple bulbs and switch cooled down, so i guess ill take out 2 lights rather than increase wire size. thanks...
__________________
ROLLIN'THUNDER
07-07-2008, 03:13 PM
|  | Old Hand | | | Join Date: Dec 2006 Location: S. CA
| | You might consider replacing a couple of those bulbs with LED lights....that way you keep the lights you want without the heavy load.
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5 (35's on order), 4.10 gears, F/Det, R/ARB, Full Roll Cage,
D44 Flat top in progress...
| | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Need Gas Mileage & Power?- Free flowing performance exhaust can
Exhaust has for your gas or diesel truck. | Off-Road Videos - Check out over ten years of extreme 4x4
action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the
dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki,
Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and
model. Read expert opinions and follow custom project vehicles. | All times are GMT -5. The time now is 06:40 PM. |
