ADVERTISEMENT
Old 05-20-2008, 04:53 PM
Journeyman
chains20 is an unknown quantity at this point
Question cj clutch master cylinder?
Hello. My part houses cant seem to get a clutch master cylinder for a 80-86 cj where is the best place to get one?
Thank you
__________________
71 commando
used to be 225/T400/D20
Soon to be 350/SM465/NP205
poor short fat white kid
Old 05-20-2008, 07:31 PM
bandhmo2 is an unknown quantity at this point
Default
NAPA and Shucks do not show them online, they show rebuild kits though. Quadratec and 4wheelerssupply both list them online.
NAPA does list a Master cylinder for YJ's (1990) that looks just like the CJ one. I wounder what is different and if it could be made to work. The most likely difference would be the threads for the line but that could be fixed with a conversion fitting.
__________________
Wilhelm
Old 05-21-2008, 01:08 AM
JeepDawg's Avatar
JeepDawg is on a distinguished road
Default
80-86 CJ Clutch Master Cyl?
Are you sure? My 84 CJ had mechanical linkage. I don't think they went to hydraulic until about 88 or 89.
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5 (35's on order), 4.10 gears, F/Det, R/ARB, Full Roll Cage,
D44 Flat top in progress...
Old 05-21-2008, 11:48 AM
Journeyman
Default
yep for some reason some cj's had linkage setup while some had Hydraulic. I know its a 7/8" bore master cylinder could there be a cj equivalent?
thank you
__________________
71 commando
  #5
Old 05-21-2008, 09:47 PM
myscrambler1 is on a distinguished road
Question hyd clutch setup
hi i have a complete unit left over from my cj8 scrambler rebuild... what are they going for... need to raise some more money for my rear full floater project so make me a offer.... do you need just master cyl ....i can post pic if you like
  #6
Old 05-23-2008, 11:46 AM
Journeyman
Default
as far as hole setup what does that consist of? I've found some for 60-70 dollers but i do not know if that is reman or new. do you happen to have the pedal assembly?. pics never hurt
__________________
71 commando
  #7
Old 05-23-2008, 07:30 PM
Smile master cyl
i will dig eveything out on sat and get you some pic no i dont have the pedals but i think i have everything else... it would be the master cyl and the coiled tube and hose if i remember right and then their is also another lower unit the rod assy that mount down low on the drivers side of the bell housing that pushes against the fork... i think i have all of that in good shape.....let me get it all out and get you the pic, then will see about price if you want it all......
  #8
Old 05-24-2008, 03:16 PM
Default cj 8 scrambler cluth hyd set up
ok here the the two main pcs you need to do hyd clutch the hyd master cyl mounts and connects to the clutch pedal via the rod/ring... and works just like your brakes, the hyd fuild when pedal compressed goes down the metal line to the the other part which is bolted to the lip edge of the bell housing and engarges the clutch fork. you will have to get a new tube hose that goes between the two or you can just use brake line and coil the line for the needed flex between them..take a look at the pic... i think you will find that if you look on ebay or price both of these as a kit they cost around $300.00 ,, i will sell both of these for $75.00 and whaterver the shipping is to you...
  #9
Old 05-24-2008, 04:51 PM
Journeyman
Default
The only thing I will be interested in is the master cylinder. do you know the history of it? Has it been rebuilt or anything?
Thank you
__________________
71 commando
  #10
Old 05-24-2008, 08:54 PM
Smile master cyl
i dont think it has been rebuilt... it was on a parts cj8 i bought for the frame... it worked four years ago when i pulled the parts jeep to my home from nebr city which is about 50 miles away... i stripped everything i wanted off it swapped the frame for my rebuild and have been selling off anything i dont need.... i cleaned out the old fluid and had it wrapped up in a plastic bag to keep dirt out of it... i never used it as anything that was on my jeep cj8 that was working ok, i just kept . it does look like it could used a new cap on top. make me a offer.
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
