Quote:
Originally Posted by LEVE Not yet... so let's drop back to basics. - The start motor turns the engine,
- but it won't fire up.
- Prior to this problem, the engine had a miss when it ran.
Is that correct?
If so.. what is missing: More information is needed. At this pont you're really saying ... "Its broke." |
Sorry LEVE, that I wasn't so clear, earlier.
The Jeep has been running OK for a week or so, but it still had a slight miss under a pull, and sometimes just idling. The only thing that was peculiar was sometimes when you went to start it, the check engine light wouldn't come on, but if you keyed it off, and then back on, everything was fine, and it would crank right up?
Mainly concern with the miss at this point...I tried some new plugs, which it needed badly. But afterwards the miss was still there?
Then after watching it run, during the night I saw some spark jump from the coil wire to the dipstick tube.
So I replaced the coil wire, and spark plug wires the next day...but still there was a miss?
So I tried a new distributor cap, and rotor button...still the miss prevailed?
So out of confusion, I went ahead and replaced the coil...the miss was still there?
So a friend was over Friday night, and we cranked it up, and was listening to it, but we couldn't figure out the miss, except maybe it was fuel related.
Saturday morning I got up determined to figure it out, but then the check engine light wouldn't come on at all, it would turn over but not crank?
Then finally Monday when I had more time to look at it, I started jiggling wires around under the hood, while the fiancee set inside watching for the check engine light.
Suddenly we heard the ASD start clicking, and after about 6-10 clicks the check engine light came on, and the fuel pump kicked in. Then she tried to crank it, and it fired right up?
Well after some research, I found where someone...had cut some ground wires in the main harness along the firewall, and had grounded them to the firewall? I don't know why anyone had done this?
I tried to clean them up, then reconnected them with solder, shrink wrapped them, and re-ground them to the firewall in hopes, that I could at least accomplish whatever the person had, that had done this???
But now the problem is it still doesn't always let the check engine light come on right away, and sometimes while I'm scracthing my head, the ASD starts clicking, and then the check engine light comes on? You guessed it...then of course it'll fire right up then?
I hope all of this really confuses you now, as much as it has me!
NOW this is going to burst your bubble??? I'm not at home right now, and the fiancee just sent me a instant message...saying..."It's working fine now!!!"
Oh well, I guess we'll see what happens from here?
