'88 Jeep Wrangler Wiring Diagram for Trailer Lights - Off-Road Forums & Discussion Groups
Old 02-06-2008, 11:52 AM
Yogi_Bear
Default '88 Jeep Wrangler Wiring Diagram for Trailer Lights
I need some help in finding a wiring diagram for my '88 Jeep Wrangler, so I can hookup some trailer lights to my jeep? I tried looking for the OEM connector but have been unable to locate it, I want to splice right into the connector intstead of using the 'light bulb connector'!!!
Old 02-06-2008, 12:46 PM
Default
In older Jeeps there's a bundle of wires running along the top of the left fenderwell, and I think that's how it was done on yours. The only connector is in front of the driver's door, so it's not realistic to connect there. Instead open up the loom and splice directly into the wires at the back corner of the tub.
And don't use those Skotch Lock thingies. Strip the wires, solder them, coat the joint with liquid electrical tape and then wrap them individually with vinyl electrical tape.
__________________
B. Dash Fabrication
Old 02-06-2008, 02:08 PM
Yogi_Bear
Default
Thanks for your response Jim, I am guessing I should pull the left taillight out to access the wires?
Old 02-06-2008, 02:16 PM
lomodyj's Avatar
lomodyj is on a distinguished road
Default
Probably be easier to go in at the back corner of the Tub. Open the tailgate look left, if your jeep ever had a hard top there will be a plug in the corner for the dome light, it comes out of a loom that has all the tail light wiring in it. There is a grommet there where the loom drops into the wheel well. Do the splicing above the wheel well (near the roll bar foot) for ease and might keep the splices out of the weather more. Then fish your trailer wires out the tailgate or out under the top. This will allow you to coil it up inside the cab when not in use, will keep some of the road crap off of it.
__________________
A bad weekend of wheelin', is still a good weekend.
  #5
Old 02-06-2008, 02:34 PM
Default
Yep, Galen, that's exactly what I meant. You want those splices inside, not in the wheelwell.
The wire for the right brake/turn light doesn't enter the left tail light, so you can't go in there. In '78 there was a white wire for both tail lights, light green with white tracer for the left brake/turn and solid light green for the right brake/turn. Good chance the same still held in '88.
To confirm that you can take a very fine needle, push it into the wire and connect your meter to it. Make your splice at the needle hole or, if you poke the wrong wire, put a little dab of liquid electrical tape on it.
__________________
B. Dash Fabrication
  #6
Old 02-06-2008, 09:39 PM
Yogi_Bear
Thanks guys for your response's, I found what you guys were describing it was right where you said it would be, which will make it easier than working upside down.
  #7
Old 02-07-2008, 08:30 AM
WILL's Avatar
Official Historian
WILL is an unknown quantity at this point
Default
I wired my 88 up for trailer lights last year. I spliced into the wires under the tub though. I have the chilton book with the wiring diagram but just used a volt meter to find the ones I needed.
__________________
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
