amc 304 to 360 head swap? - Off-Road Forums & Discussion Groups
Old 01-27-2008, 12:10 AM
Stranger
jshankcj7 is on a distinguished road
Default amc 304 to 360 head swap?
Hello I am rebuilding and modifying my 76' AMC 304. I was just wonderin if anyone would know if amc 360 heads would fit and would I need to change anything and would it add horse/torque?
Old 01-27-2008, 01:54 PM
Caver Dave's Avatar
Caver Dave is an unknown quantity at this point
Default
IIRC, some folks have done it for the larger valves alone, but it may also introduce the possibility for valve to block/piston contact. PM Elusive... I think his old "TJ-7" was running 360 heads on the B&B 304
You may be able to glean some info from this PDF. I used it to confirm my "new" heads were indeed for a 304...
__________________
Caver Dave
'72 "Mossy Edition" Commando
the Trail Forge
Old 01-27-2008, 04:53 PM
HOGHEAD's Avatar
HOGHEAD is an unknown quantity at this point
Default
Why not just go with a 360 ,,, Put a old set of heads (69 or 70) I think its 53 cc heads compaired to 86 cc on newer (78to86) ,,, You have to over size the head bolt holes on the older heads & make sure you install hardened seats,, I installed a older set on a 78 once & it ran ,,,, Well good,,, run the compression from 8.6to1 to 11to1,,,, Iv got a old set of those heads ,,, But with the gas prices I havent used them yet,,,
__________________
SOME BEACH ,,,,,
DEATH BEFORE 2 WHEEL DRIVE ,,,
Quando omni flunkus moritati ,,,
Proud American
Save the Earth... it's the only planet with chocolate
Old 01-27-2008, 05:00 PM
SilentBob2's Avatar
SilentBob2 is an unknown quantity at this point
Default
I can't say for sure it would work, but there are a lot of options for the AMC's. I did not build the 360 I have in the scrambler but the guy I got it from must have known a few things about AMC's. I do know you can build a stroker using a 360 block and 401 crank among other things. If you do a search on the net for AMC motor build ups, you will find some good info.
Here is a couple of sights.....
Jeep Engines - The AMC V8 Engines
Here's a forum...
AMC ROCKS! :: Index
An AMC Sroker?
This one says not to waste your time with a 304..
AMC V-8 Engine - Tech Articles - Jp Magazine
I know you can find it if you look for it, I would just suck it up and build you a 360 stroker. Im positve you wouldn't regret it. From what I have seen, It should work. You could allways go to your local parts store and have them pull out a head gasket for each to compare and if they have the same part # for the gasket, well then it should work would be my geuss....
  #5
Old 01-27-2008, 10:30 PM
WILL's Avatar
Official Historian
WILL is an unknown quantity at this point
Default
I have 360 heads on my 0.060 bored 304. I only did it because my 360 block was bad and one 304 head had a crack. It runs fine but I miss the power of the 360.
__________________
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
