ADVERTISEMENT
Old 10-29-2007, 11:33 PM
drunkinhillbilly's Avatar
Newbie
drunkinhillbilly is on a distinguished road
Default Tbi 350
I have a 350 out of a 94 chevy 2500 with throttle body fuel injection that i want to put in my CJ. i have the trans and every thing else figured out except for how to run the TBI. the problem is that all the wires that went through the fire wall were cut. does any one know of a cheep standalone system for the TBI? or how to make it work with a stock computer?
__________________
Colin
37s, beadlocks, coilsprung locked 14bolt portal axles front and rear, 6.5 GM diesel, camo paint and 50cal mount.-- work truck
Old 10-30-2007, 01:09 AM
JeepDawg's Avatar
JeepDawg is on a distinguished road
Default
Boy....am I the guy you want to talk to..........
I finished a SBC swap into my 84 CJ about a year ago....
First off....who ever chopped the wiring harness did not know what they were doing.
The wiring is actually a lot easier than it seems.
Go to a junk yard and pull the wiring harness from a donor veh....92-94 is just about the same...the only thing different is the VSS (Vehicle Speed Sensor). You want the harness all the way to the computer. There are also a few wires that go to the fuse block inside the engine bay. You only need a couple of those wires......mine harness had been cut there so it was the biggest problem for me to trace out.
You will end up pulling out your existing computer harness and computer. There will also be a couple other wires in your chassis harness (left side under the brake MC...fuse block).
You will want the FSM for you jeep and the FSM for the donor truck.
The new harness will fit nicely through the hole of the old computer (after you enlarge it a little) and the new computer in place of the old one.
In reality, there are only about a dozen wires that you have to hook up....about 6 to get it running...the rest or for the OBDI connector, CEL, etc.
Last thing....the computer and harness also include the wiring for the transmission....the donor veh you get the harness from has to be the same transmission type....if you are running an auto you will need the harness from a truck with an auto......hopefully you are going auto...the 4L60 is a great tranny....
__________________
AKA DDawg16
84 CJ7, SOA, 5.7LTBI, 4L60E, 32"x11.5 (35's on order), 4.10 gears, F/Det, R/ARB, Full Roll Cage,
D44 Flat top in progress...
Old 10-30-2007, 05:12 AM
Newbie
Default
thanks for the info.
im running a T176 with a custom bellhousing adapter and a Dana 300. will i need to get a computer from a 5 speed? what does the computer monitor from a 5 speed? how do i know which wires coming off the computer do what and what i dont need? does the computer control the guages or can i just run my own? is there a schimatic available to identify which wires do what?
__________________
Colin
Old 10-30-2007, 10:50 AM
JeepDawg's Avatar
Default
Ya gotta read the full post......
I don't think it matters what speed tranny the manual is....it only monitors the clutch. You will need to install a VSS sensor in the tail of the transmission so the computer knows what the speed is (not the xfer case)...unless you get the harness from a 4wd veh....
Gauges....you will not use most of the wires from for the gauges from the computer......instead you use your own oil pressure sender and temp sensor....I installed my oil sending unit in a port by the oil filter....the temp sender is using a spare hole in the right head............
I'll explain all of this in detail AFTER you get the FSM (Factory Service Manual) for the jeep and truck.....and get the wiring harness from the right truck. In many cases you are going to find a truck in the junk yard that has the engine pulled and the harness is just laying there. Another option is painless wiring..they may have a harness already set up.
__________________
AKA DDawg16
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
