Need help building CJ frame - Off-Road Forums & Discussion Groups
Old 06-30-2007, 10:05 AM
jps4ever's Avatar
jps4ever is an unknown quantity at this point
Default Need help building CJ frame
This is for a friend that was ran off the road and was left pinned under his jeep. The jerk that pull out in front of him didn't bother to stop. The jeep was totaled and he is poor like most of us here and can't afford to buy a frame. I did some searching on the net but found very little info for building a frame from scratch. Any tips, hints, pics or links would be much appreciated. My friends leg is about healed up now and I would like to help him get his jeep back on the road.
Dave
Old 06-30-2007, 10:19 AM
JeepnGreg's Avatar
JeepnGreg is on a distinguished road
Default
are you guys going tube frame? or just fix the stock frame?
if going tube, and he's really strapped for cash....
consider buying a used frame.....they are available farily often from people who cannibalize other jeeps for bodies and parts. and are usually really really really cheap.....much cheaper than building a tube frame, or going through the effort of repairing a frame thats been bent and twisted
dont forget to consider YJ frames if its a CJ7...
for example:
eBay Motors: jeep cj7 chassis frame spring over & 350 ready (item 270137070123 end time Jul-01-07 17:45:00 PDT)
eBay Motors: JEEP YJ WRANGLER FRAME 1987-96 (item 190126841175 end time Jul-01-07 18:02:34 PDT)
eBay Motors: Late 70's Jeep CJ5 Frame in Great Condition (item 290133909391 end time Jul-05-07 10:21:51 PDT)
__________________
Doesn't-have-a-Jeep'n Greg
VISIT MY GUN STORE: http://www.AmericasBasement.com
Old 06-30-2007, 10:20 AM
Default
I can send the drawing with measurements from the FSM. Is it a 5 or a 7?
It's probably not possible to build a frame cheaper than buying a used one and repairing it as necessary. When I restored my Jeep the frame needed a lot of rust repair. I thought about building a whole new one, but just the steel would have cost $300, and it would have taken days and days of work. And then it wouldn't duplicate the stock frame, just be close enough to work.
He's going to need a lot of body parts too. I'm sure that he'd be way ahead buying a worn out CJ or YJ and putting his mechanicals into it.
__________________
B. Dash Fabrication
Old 06-30-2007, 12:05 PM
jeepgod's Avatar
jeepgod is an unknown quantity at this point
Default
I would look at getting a used a frame.. and i would look for a yj frame.. much stronger than a cj.. and more plentiful in the boneyards.. also consider tj frames.. its not a lot of work to put them under a cj.. i have done both..
here is a link to the frame dimensions on my page.. out of a chiltons/haynes manual..
http://www.jeepgod.net/information/cj7frame.jpg
__________________
Survival is instinct, Living takes guts!
  #5
Old 07-01-2007, 02:15 AM
jdoggmoney's Avatar
jdoggmoney is an unknown quantity at this point
Default
I would also suggest a relacement frame, YJ if possible. But... there is more to it than simply swapping in your old CJ driveline. I just went through this... swapping my CJ driveline into a YJ frame and tub. There are several issues that will require some thought and fabrication.
__________________
Is this the only hammer you've got?
  #6
Old 07-01-2007, 07:03 PM
Journeyman
LMAO@U is an unknown quantity at this point
Default
I know a couple guys that cut up Suburbans, Older Blazers, Broncos, Pick-up trucks and turn them into a Jeep frames (Of course they're a little different) they weld in the body mounts, shock mounts, trim the frames and walla... Minor stuff. Getting the frame free from the body and other goodies is another story. (just a little food for thought)... if you have a good donor then that's all that is needed.
  #7
Old 07-04-2007, 02:05 PM
jps4ever's Avatar
Default
The jeep was a CJ5 but he has decided to build a 7. I sold him a tub and he has found a few deals on other parts needed. The frame is really the only hold up. His is trash and can't be repaired. He was thinking of building the frame because of a deal he was working on for some tubing he could pick up for cheap. I don't know how hell bent he is on building the frame but I'm sure he would rather pick up a good used one if he could find one cheap. They are a little harder to come by in our small town. We are not far from Collins Bros Jeep but their frames start at $750. We'll keep looking. Good idea building a jeep frame from a truck or something, I had never thought of that.
  #8
Old 07-04-2007, 10:38 PM
spook2 is an unknown quantity at this point
Default
Quote:
Based on the price they attach to most of their parts, I'm quite sure everything Collins Bros. sells is gold plated. They must cater to the terminally wealthy and stupid because I can't imagine how they would stay in business otherwise.
  #9
Old 07-05-2007, 09:36 AM
Junk Yard Genius's Avatar
Junk Yard Genius is an unknown quantity at this point
Default
You probably want to look for a salvage frame.
Cheap, easy, tabs and holes are already where they are supposed to be, ect.
Welded frames are very heavy, and welded joints always seem to crack with time unless you reinforce the crap out of them, then the frame is that much heavier...
I've built my own frames, but I just was never satisfied with the results or the weight.
__________________
(WWHLD!)
"What Would Hannibal Lecter Do?" With my Jeep!?
The 'Fillet The Other Cheek' philosophy!
  #10
Old 07-05-2007, 02:26 PM
Default
There's a lot more to making a good weld joint than making a good weld - the design has to be right and the weld has to be in the right place. Several years I got a small booklet with a bunch of tips about how to make a good joint. One of the things mentioned is that adding more weld in the wrong place can actually cause a failure. It's an interesting subject that I wish I understood better, but I understand it well enough to realize that a frame isn't something just anybody can make, even if they are an outstanding welder.
__________________
B. Dash Fabrication
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
