How to clean a TBI injector? - Off-Road Forums & Discussion Groups
Old 04-27-2007, 11:51 AM
Journeyman
GeCJ7 is an unknown quantity at this point
Default How to clean a TBI injector?
Looks like one of my TBI injectors is not spraying very well. Compared to the other one which spray a nice even mist, the other one seems to have more of a heavy droplet spray.
How do you, or can you, take the injector out to inspect what is causing the bad spray pattern. Itís a new Howell TBI conversion on a rebuilt 258. The TBI did sit for about two years dry before I was able to install it. Searched and could not find any posted write-ups.
Thanks
Old 04-27-2007, 12:08 PM
Junk Yard Genius's Avatar
Junk Yard Genius is an unknown quantity at this point
Default
Use a timing light hooked to the coil wire to see the actual spray cone and droplet configuration.
(Old Mechanics trick)
The stroboscopic effect will make the spray pattern a 'Stop Action' so you can get a good look at it.
If you want to slow the flashes down, connect to one of the spark plug wires...
Cleaning is easy depending on what type of injectors you have.
Some can be removed and manually cleaned.
Others have to be 'Pressure Cleaned' in place with a special solvent.
Still others can't be practically cleaned and have to be replaced...
Howell uses an early type of GM TBI that can be disassembled and serviced.
Personally, I'd take them apart, clean them with a healthy solvent, paying particular attention to deposits around the nose, and reassemble with fresh seals.
Remember, don't use a wire brush or anything that can scratch the injector or the injector body!
Nylon brush and strong solvent will do the trick.
__________________
(WWHLD!)
"What Would Hannibal Lecter Do?" With my Jeep!?
The 'Fillet The Other Cheek' philosophy!
Old 04-27-2007, 12:13 PM
Journeyman
Default
Yes, its working, or running if thats what you mean.
Thanks
Old 04-27-2007, 03:55 PM
Carpal \'Tunnel
TiminMb is an unknown quantity at this point
Default
Nice pictures of disassembly:
WitchHunter Performance - Throttle Body injector removal
They do not work right unless they are properly spraying.
You might be well off to remove both injectors yourself and take them into a specialty shop to have them clean and test them. They have the right tools to clean and test them.
  #5
Old 04-30-2007, 10:11 AM
Journeyman
Default
Thank you! Thats is perfict.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
