| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeep-Short Wheelbase All discussion of short wheelbase Jeeps: CJ, TJ, YJ |
03-13-2007, 09:21 PM
| | Newbie | | | Join Date: Aug 2006 Location: Pa.
| | Spun "Nuts" in frame. This is the first time I've logged into the new format and it's pretty nice.
I have a YJ with at least 2 "nuts" that hold the Trans skid plate on that have spun, (broken the crappy welds that held them), so I can't remove the skid plate.
I have seen a few fixes and I was wondering what the group has to offer for the best, (easiest), fix.
My friend had all 6 spin and cut windows in the frame and welded the "nuts" fast, then rewelded the windows closed. My least desirable choice.
I think LEVE sent me a picture of a weld around the nut from the bottom side of the frame, but they are pretty rusted out and I dont think that the area around the nuts is up for welding.
A local 4 X 4 shop told me that they plasma cut holes where the nuts were and weld a plate, (around 1/8" thick), that has the proper nuts welded to it in the right locations, on to the bottom of the frame rail.
Someone else said that they cut a slot into the frame and slid a rectangle of steel that had a drilled and tapped hole in it so it wouldn't spim.
So many ways to remedy the problem.
Has anyone "gone there, and done that" and has some advice?
Thanks,
Mike |
03-14-2007, 06:51 AM
|  | Super Moderator | | | Join Date: Dec 2001 Location: Belleville, Illinois
| | As is often the case, easy and best are mutually exclusive. This is a pretty good repair, and not terribly difficult. http://forums.off-road.com/jeep-shor...rame-nuts.html (A repair for messed up frame nuts)
If the bottom of the frame is really rusted too badly for this repair, you'd better cut it out completely and weld in a new piece of steel, with nuts welded to the inside.
__________________
EVERYTHING's easy for the guy who doesn't have to do it. B. Dash Fabrication |
03-14-2007, 08:15 PM
|  | Enthusiast | | | Join Date: Sep 1999 Location: Boilermaker Country USA
| | Jim_Lou,
AWESOME problem-solving. I admire you and so many others in this forum. I checked out Stainless Steel Jeep Restoration and under your two pictures of the drilled frame and insertion tool, "The old nut is drilled out, a hole prepared in the frame and a threaded insert machined. The insert is screwed onto an insertion tool and pulled into position through the frame tube." Do you sell this insertion tool or is this a custom made piece? Thanks
__________________
Eight years later, with all of your help, finally got a 94 4.0 running in my 85 CJ8. Newly painted it a Toyota Voodo Blue like you see on the new FJs. Trying to figure out the 94 OEM YJ AC wiring harness. ><>
03-15-2007, 06:39 AM
| | There's nothing to the insertion tool, or the inserts either. I can make some for you, or if you want to have them made locally I'll send you the drawings.
__________________
EVERYTHING's easy for the guy who doesn't have to do it. B. Dash Fabrication | | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 01:07 AM. |
