ADVERTISEMENT
Old 03-13-2007, 10:21 PM
Newbie
Nimrod57 is an unknown quantity at this point
Default Spun "Nuts" in frame.
This is the first time I've logged into the new format and it's pretty nice.
I have a YJ with at least 2 "nuts" that hold the Trans skid plate on that have spun, (broken the crappy welds that held them), so I can't remove the skid plate.
I have seen a few fixes and I was wondering what the group has to offer for the best, (easiest), fix.
My friend had all 6 spin and cut windows in the frame and welded the "nuts" fast, then rewelded the windows closed. My least desirable choice.
I think LEVE sent me a picture of a weld around the nut from the bottom side of the frame, but they are pretty rusted out and I dont think that the area around the nuts is up for welding.
A local 4 X 4 shop told me that they plasma cut holes where the nuts were and weld a plate, (around 1/8" thick), that has the proper nuts welded to it in the right locations, on to the bottom of the frame rail.
Someone else said that they cut a slot into the frame and slid a rectangle of steel that had a drilled and tapped hole in it so it wouldn't spim.
So many ways to remedy the problem.
Has anyone "gone there, and done that" and has some advice?
Thanks,
Mike
Old 03-14-2007, 07:51 AM
Super Moderator
Default
As is often the case, easy and best are mutually exclusive. This is a pretty good repair, and not terribly difficult.
http://forums.off-road.com/jeep-shor...rame-nuts.html (A repair for messed up frame nuts)
If the bottom of the frame is really rusted too badly for this repair, you'd better cut it out completely and weld in a new piece of steel, with nuts welded to the inside.
__________________
B. Dash Fabrication
Old 03-14-2007, 09:15 PM
DuaneD's Avatar
DuaneD is an unknown quantity at this point
Default
Jim_Lou,
AWESOME problem-solving. I admire you and so many others in this forum. I checked out Stainless Steel Jeep Restoration and under your two pictures of the drilled frame and insertion tool, "The old nut is drilled out, a hole prepared in the frame and a threaded insert machined. The insert is screwed onto an insertion tool and pulled into position through the frame tube." Do you sell this insertion tool or is this a custom made piece? Thanks
__________________
Eight years later, with all of your help, finally got a 94 4.0 running in my 85 CJ8. Newly painted it a Toyota Voodo Blue like you see on the new FJs. Trying to figure out the 94 OEM YJ AC wiring harness. ><>
Old 03-15-2007, 07:39 AM
Super Moderator
Default
There's nothing to the insertion tool, or the inserts either. I can make some for you, or if you want to have them made locally I'll send you the drawings.
__________________
B. Dash Fabrication
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
