OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Old 03-13-2007, 09:16 PM
Newbie
Nimrod57 is an unknown quantity at this point
Default Spun "nuts" in the frame.
This is the first time I've logged into the new format and it's pretty nice.
I have a YJ with at least 2 "nuts" that hold the Trans skid plate on that have spun, (broken the crappy welds that held them), so I can't remove the skid plate.
I have seen a few fixes and I was wondering what the group has to offer for the best, (easiest), fix.
My friend had all 6 spin and cut windows in the frame and welded the "nuts" fast, then rewelded the windows closed. My least desirable choice.
I think LEVE sent me a picture of a weld around the nut from the bottom side of the frame, but they are pretty rusted out and I dont think that the area around the nuts is up for welding.
A local 4 X 4 shop told me that they plasma cut holes where the nuts were and weld a plate, (around 1/8" thick), that has the proper nuts welded to it in the right locations, on to the bottom of the frame rail.
Someone else said that they cut a slot into the frame and slid a rectangle of steel that had a drilled and tapped hole in it so it wouldn't spim.
So many ways to remedy the problem.
Has anyone "gone there, and done that" and has some advice?
Thanks,
Mike
Old 03-13-2007, 09:26 PM
Saddle Tramp is an unknown quantity at this point
Default
I have drilled holes in the side of the frame with a hole saw and then tack welded the nuts down as needed. You can then use the piece from the hole saw to use with frame repair. That's just what I have done.
Kriss
__________________
1978 CJ5, AMC 401, CJ T18, Scout D300, 2 1/2" Lift, Locked Front/Back
Old 03-14-2007, 12:10 AM
I am in the CPU
RRich is an unknown quantity at this point
Default
All those "cures" are alot of work - holes cut, even when welded up afterwards weakens the integrity of the frame.
But it's a common occurance.
First cut off - grind, torch etc - the bolt heads so you can drop the crossmember or whatever it is.
Knock the piece up inside the frame so you have a hole there.
When you want to put it back - simply tack weld or even JB Weld a hunk of weld rod to the head of the new bolt you want to use.
Simply fish the new bolt through one of the existing holes in the frame - even if it's several feet away - there are a bunch of them - till the end of the bolt sticks through the hole where you want it. Put the skud plate in position and put a nut on the bolt.
When you tighten it, the bolt head is tightening against the rough surface where the weldnut was - it doesn't turn.
It's easier to fish a bolt through than a nut, but that's possible too.
Easy, simple, fast.
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
