| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeep-Short Wheelbase All discussion of short wheelbase Jeeps: CJ, TJ, YJ |
03-13-2007, 03:09 PM
| | Enthusiast | | | Join Date: Mar 2007
| | Weld dependent high steer arms? I have a buddy that just picked up these in his words "super sweet" high steer arms off e-bay. They are double ended arms to put the tie rod behind the axle. Instead of just being machined out a single piece of steel they are made out of 2 pieces and are connected with a lap joint. They overlap maybe 1/8" and have 3 passes of weld on each side, no gussets, very much weld dependent. They have some grinding for some sort of clearance on the back side that looks like a 4 year old did it. They also came primed on all sides which my understanding is paint on the surface where the arm meets to the knuckle is not acceptable.
Am I right by telling him to return them or throw them in the grabage? They are going on a jeep that he plans to run in the stock mod uroc class and also running it on the street. The whole weld failing and taking out a family of 4 is what scares me. I'm not touching the steering for fear of the e-bay cobble killing some one, am I actually thinking right for one? |
03-13-2007, 03:54 PM
|  | Keyboard Implanted | | | Join Date: Mar 2000 Location: East Peoria, IL
| | could you get a picture?
seems shady.....but theres more to it than just being weld dependant.
what type of weld, what weld material, weld radius, length of the weld bead, is it welded on both sides?
as for paint on the knuckle.....to my knowledge there isnt anything wrong with that, but i suppose it could vary with the type of rod end you are using
if you describe it as being garbage-esque, then it prolly is.....but post a pic if you can.....or ebay link....or sometihng that might give a better idea
__________________
Jeep'n Greg
1975 CJ-6 "Project Mud Dauber"
03-13-2007, 04:22 PM
|  | Old Hand | | | Join Date: Jun 2002 Location: Cottonwood, AZ / Wherever the road takes us
| | Quote:
Originally Posted by barrelroll am I actually thinking right for one? |
I think you are. I know I wouldn't touch something like that, or ride with anyone who did.
__________________ 1974 CJ5, D30, D20, D44, T15, 2.5" BDS Lift, 33's, Dual ARB's, 4.27's, Front Cage
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
03-13-2007, 05:15 PM
| | I am in the CPU | | | Join Date: Sep 1999 Location: Johnson Valley, CA
| | If it's bad enough to question I sure wouldn't want you using it. And I wouldn't want you coming toward me or passing me either.
Ditch it quickly before someone gets hurt. |
03-13-2007, 07:43 PM
| | Addict | | | Join Date: Dec 1999 Location: Ohio
| | I'd have to go with the group on this one. Just based on a description I'd be loath to trust my butt to a welded together steering arm. Speaking of which, I can't imagine why it's welded together instead of a single unit. The second thing that get's me is that it's only lapped by 1/8". That sure doesn't leave much support at the joint, nor does it allow for much of a weld bead. Unless the picture is worth at least 250 words worth of explanation I don't see this being anything but a quick buck booty fab on someone's part. |
03-13-2007, 08:08 PM
|  | Old Hand | | | Join Date: Sep 1999 Location: Tennessee
| | I went to the item and looked at it... That's pretty darn funny. Looks like the guy took a stock arm and a spacer and welded some crap on it then painted it to hide any "imperfections" in his welding. I wonder if you have to sign a waiver before buying those.
__________________ New GreenMachine coming soon!!!!! |
03-13-2007, 08:27 PM
| | yea those arent real good.
i would avoid
they'd prolly split right along the weld there the first time you tried to turn against an obstacle.
__________________
Jeep'n Greg
03-13-2007, 08:43 PM
| | Quote:
Originally Posted by barrelroll | What it "looks" like is that someone took a set of one piece arms, cut them in half and then welded them back together with that offset. Some sort of clearance issue I'd guess. If they had the skills to CNC those things, then then had the skills to cnc them out of one piece of steel. Those are booty fabbed and your buddy got taken. The ONLY machine I'd put those on would be a trail only machine, and at that I'd only use them as backup replacements for the GOOD pair I somehow managed to screw up while on the trail. IOW, those are garbage.
I run a weld shop for a living and a fillet welded lap joint like that will NEVER be as strong as a solid steel piece. You might stand a chance if you get 100% penetration of your joint AND you anneal it properly AND you stress relieve it properly. I'd wager those parts have none of the above.
If you value your buddys life, GIVE him the 60 odd dollars he wasted if you have to, but don't let him install that crap on something to be driven at ANY kind of speed. Scratch that. Don't let him install that crap, period. |
03-14-2007, 05:46 AM
|  | Keyboard Implanted | | | Join Date: Nov 2001 Location: Kansas
| | I don’t see a problem with the way the weld is done. I’ve seen a lot of welds in tension or shear support a lot of weight. We hang complete cars and trucks from not much more. Trains run on rail butt welded together. If this scares you, take a look at the chain you’ve been using to hoist your engine. You guys weld those threaded plugs in the end of a piece of tube for a tie rod and think nothing of it.
Weld can be very strong. I’m not a welder so I’ve never taken the test but as I understand it, the job certification test goes like this. Two pieces of steel bar are laid on a thinner plate with a gap between them. I believe the bars are 1 x 4 bar and the gap is one inch. The welder taking the test fills the gap with weld. The plate is ground off the back and the piece is placed in a bender. The piece is bent at the weld and it must bend without cracking. But what would be the point of having a test that anybody can pass? So, one concern is who did the welds?
Would I use them? NEVER! There is a much bigger problem you've missed.
__________________ There are 10 kinds of people in the world.
Those who understand binary and those who don't. | | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 02:41 PM. |
