| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeep-Short Wheelbase All discussion of short wheelbase Jeeps: CJ, TJ, YJ |
02-20-2007, 06:39 PM
|  | Aprentice | | | Join Date: Sep 2006 Location: Scott AFB, IL
| | Engine off center? Is this typical?
I've got a 77 CJ-7 with a GM 350 under the hood. I first noticed it looking at the headers, but Looking closely at the centerline of the engine, sure enough, it's about 2-3" off center. I've got more engine on the driver's side. This throws a small wrench in my future exhaust plans, as I wanted to run side pipes just off the headers.
thanks, Mark |
02-20-2007, 09:02 PM
|  | Old Hand | | | Join Date: Oct 2002 Location: Noel MO. USA
| | Re: Engine off center? That should be correct to have clearance for the front drive shaft. You should be able to pick up a set of fenderwhale headers for about $150 if your wanting side pipes! |
02-20-2007, 09:16 PM
| | Re: Engine off center? Thanks for the info. You saved me a bit of concern, and pointed me in the right direction for "matching" headers.
V/R, Mark |
02-21-2007, 01:33 AM
| | Re: Engine off center? [ QUOTE ]
I couldn't get any hits on Fenderwhale as a brand name. I'll probably just find a way to make mine work, but i'd like to see what's out there for this sort of application.
Thanks, Mark |
02-21-2007, 07:02 AM
|  | Super Moderator | | | Join Date: Dec 2001 Location: Belleville, Illinois
| | Re: Engine off center? He probably means "fenderwell" headers, which dump outside the frame rails - not a good choice IMO.
The tightest place on the driver's side is between the bellhousing and the frame, which happens to be right where they put the brake valve. There's room for exhaust there, and you can move the valve if necessary.
On the passenger side the front drive shaft is the problem. Several guys on the board have gotten a pipe through there - DDawg, Thor and P Nut I think have done it. |
02-21-2007, 11:23 AM
|  | Old Hand | | | Join Date: Dec 2006 Location: S. CA
| | Re: Engine off center? My SBC is offset to the drivers side about 1.5326"...I don't think you are offset as much as you think...1" off center looks like a lot more than just 1".
And as noted above, forget headers. They are high maintenance, high noise, High failure and highly overrated. They do nothing for your low end performance.
I would suggest a good set of Ram Head exhaust manifolds... |
02-21-2007, 11:34 AM
| | Pooh-Bah | | | Join Date: Aug 2001 Location: Vermont
| | Re: Engine off center? It is pretty normal to offset a motor when swapping it in. My 350 is offset 1.75" to the drivers side to clear the front driveshaft.
If you run a chevy 350, with a turbo 350 and a Dana 300, and your motor is not offset a little... you end up with real driveshaft clearance issues. I offset my motor in my jeep just in case I ever want to go to an automatic. |
02-21-2007, 07:01 PM
I must be using the "man ruler"; not necessarily known for its accuracy.
[ QUOTE ]
My 350 is mated to a T-400 automatic, via an adapter plate. (That one made me scratch my head!) Turns out it's the factory transmission and has an AMC bell housing pattern.
Chances are I'll just leave these headers on. Call me crazy, but I'm thinking of putting some late 60's style muscle car side pipes on it. The engine/headers being a little off center means I'll have to be creative to make both sides come out the same.
Despite my weird ideas, thanks for letting me know the engine mounting is normal.
Olin 18 - I like your signature quote.
Thanks, Mark |
02-24-2007, 10:36 PM
| | My bad on the spelling up above but if your wanting the muscle car side pipes, you need to look at the set of Hedman headers for $169 at 4wheeldrive hardware. They done away with the collector gaskets on the bottom. I don't know what you would call it, but the collector now sleeves over the bottom of the header eliminating the lower gasket. Thats the only place I ever had trouble with. Hedman - Jeep Parts and Jeep Accessories & Tops by 4 Wheel Drive Hardware
__________________
Scrambler
CJ-5
51'Willys
Jeepster
Need I say more?
02-25-2007, 12:48 AM
| | I've seen those. I think that's basically what I've got, coming out from under the fender. They just don't account for that 'slightly off-center' factor. I'll make something work eventually. Adding the black side pipes is just a thought. I'll try and photoshop it first, just to see what proportions might look good.
If this link works, you can see a close up of the headers. Right now they take a hard 90 degree angle in and then another 90 degree back to get to the mufflers. That can't be very efficient. http://lh5.google.com/image/mthatch/...JPG?imgmax=144
__________________
FT-847 with ATAS-100 & 77 CJ-7 ground plane.
| | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 08:48 PM. |
