| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeep-Short Wheelbase All discussion of short wheelbase Jeeps: CJ, TJ, YJ |
02-20-2007, 06:29 PM
|  | Super Moderator | | | Join Date: Dec 2001 Location: Belleville, Illinois
| | Re: Trouble cranking when warm! [ QUOTE ]
Should I be concerned about leaving the vacuum advance off for now?
Depends on your definition of trouble. It should start and run fine, but fuel useage will be way up. The vacuum advance is mainly an economy thing. Plug it back in. It has nothing to do with hard starting because it's inactive during starting. |
02-20-2007, 09:52 PM
|  | Aprentice | | | Join Date: Sep 2006 Location: Scott AFB, IL
| | Re: Trouble cranking when warm! The cranking is probably fine either way now. My commute is 2 miles so I'm not too concerned about the mileage yet. I think the vacuum advance is advancing too far. Can that happen?
Thanks, Mark |
02-21-2007, 09:15 AM
| | I am in the CPU | | | Join Date: Sep 1999 Location: Johnson Valley, CA
| | Re: Trouble cranking when warm! Sounds like you either have the WRONG source of vacuum to it - you have manifold on it now, or someone got creative and bypassed the solenoids that control it - a typical problem.
Either find the RIGHT vacuum source (ported) - preferred - or connect the solenoids correctly.
You'll notice a big improvement on performance and mileage. |
02-21-2007, 11:03 AM
|  | Old Hand | | | Join Date: Dec 2006 Location: S. CA
| | Re: Trouble cranking when warm! It's real unusual for a bad battery to show up with the engine hot....it's the cold the usually kills the battery....
I'll take my crow raw....just like my Sushi |
02-21-2007, 06:40 PM
I think the failing alternator killed the battery early. The new one sure works great. I knew the voltage regulator was out just by watching the lights dim. Although that can still be typical at a very low idle.
I've got an early 70's GM 350 with an Edelbrock 4 barrel and Victor Jr. intake. (and misc other chrome the Jeep came with)
The vacuum hose was on a port on the lower front side of the carb. The guy I bought it from may not have known where it should be connected. (come to think of it, I don't either) I figured the vacuum diaphragm on the distributor might be old and moving the advance too far. I hadn't considered the hose being plugged into the wrong port. (it also crossed my mind that there might be a vacuum advance adjustment inside the distributor)
At least the weather is great.
Thanks, Mark | | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Need Gas Mileage & Power?- Free flowing performance exhaust can
Exhaust has for your gas or diesel truck. | Off-Road Videos - Check out over ten years of extreme 4x4
action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the
dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki,
Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and
model. Read expert opinions and follow custom project vehicles. | All times are GMT -5. The time now is 08:35 AM. |
