headlights not working - Off-Road Forums & Discussion Groups
Old 09-25-2006, 07:11 PM
jclefty
Default headlights not working
Replaced headlight switch and headlights on a 85 cj7 but still nothing. Could not find fuse for headlights just parking and tail lights (which work ok). If dimmer switch is bad will this cause headlights to not come on. Went to auto parts store to buy a headlight relay. It was listed but something they could not get. Is this different than the headlight switch, if so where is it located. Is there a fuse somewhere other than fuse box.
Old 09-25-2006, 07:27 PM
Default Re: headlights not working
A bad dimmer switch can cause the lights to not work at all, but it's unusual. More commonly one side of the switch goes out, usually low beam. A headlight relay was not a factory part on older CJ7s, and I doubt one was used on the late ones but I don't know for sure.
Before you throw more parts at it, take a systematic approach. There are three wires going to the dimmer switch. The red one with the white stripe carries power to it. The gray and gray with white stripe are the low and high wires to the bulbs.
Unplug the connector from the dimmer switch, turn on the headlights and see if you have battery voltage on the red wire. Then test the resistance to ground on the gray wires. It should be a fraction of an ohm.
If that tests out, it is almost certain that the dimmer switch is bad. If you don't have power, the problem lies in the headlight switch or the wiring from it to the dimmer. If you have an open or very high resistance on the gray wires the problem is in the firewall connector or the wires from the dimmer to the lights, or from the lights to ground. Don't forget to checkj your grounds.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
