ADVERTISEMENT
  #11
Old 04-12-2006, 12:24 PM
wbcarver's Avatar
wbcarver is an unknown quantity at this point
Default Re: CLUTCH HELP
[ QUOTE ]
Leve,
At Autozone they only sell the individual components not an assembled unit.
Go figure.
However looks like mine will work now.
Brad
So you got it working alright?
What did you have to do?
  #12
Old 04-12-2006, 01:22 PM
I am in the CPU
RRich is an unknown quantity at this point
Under "normal" circumstances it should be self-bleeding.
Any air in the slave or lines tends to travel upwards.
A bubble in the slave gets disturbed when you operate the pedal, it gets sucked into the line. The line should not have any kinks or loops in it, the entire line slopes upwards. That lets the bubble slowly work it's way upward to the master, where it gets out.
It would be nice if brake lines worked the same way, but unfortunatly they have to go much farther and twist around things, causing places where the bubbles get trapped. That's why they aren't self bleeding.
  #13
Old 04-12-2006, 02:41 PM
KentuckyCrawler is an unknown quantity at this point
Bill,
Well I went to work on some other small items and came back to it later. Pumped the heck out of the pedal and I guess worked the air out of it because I was getting better restriction and operation the longer I operated the pedal.
Brad
  #14
Old 04-12-2006, 02:53 PM
wbcarver's Avatar
Cool deal.
That is probably exactly what happened.
Sometimes you get lucky like that.
Like RRich said, *in theory* they should self-bleed.
But in actual practice, we rarely have the time or patience to wait it out.
  #15
Old 04-12-2006, 04:52 PM
I am in the CPU
It shouldn't take but a few pumps - unless it's sucking air in at the slave.
Check to make sure there's a light spring on the slave, pulling it back. Sometimes the rebuilders or Chinese aftermarket folks don't put the spring inside, so use one externally.
Cups need a slight amount of pressure to keep the lips extended and sealed. That's why drum brakes use a light check valve to keep the pressure up a little.
Search this Thread:
Advanced Search
Pit Bull Tire -
Need Gas Mileage & Power? -
RH2way.com -
Katech Performance -
